Is this an LS1 or LS6 intake?
Heard if its got an EGR hole after the throttle body then its LS1. Well i see two hoses going in the intake from either side of the throttle body. The white stick in the pic is pointing to them.
It's on the drivers side between the two middle injectors.
http://www.dumontduneriders.com/invi...1336839732.jpg
FYI, the LS1 dips down in the middle on the bottom, the LS6 is flat.
Some LS1 intakes didn't have the egr, and look very similar to an LS6. The best way to find out is get the part number or look at the bottom of the intake. The bottom of an LS6 intake is flat, the LS1 has a hump.
To the OP, that number is an LS6 intake part number like said above.
