bcm help 2000 T/A
Old 01-24-2014, 07:11 PM
dolfins1a's Avatar
Default bcm help 2000 T/A
Having issues with the keyless entry for a while and now key fobs won't open doors at all. I've replaced the batteries and tried reprogramming the remotes, the car goes into programming mode but the remotes won't program when holding the lock and unlock button. Is it possible the bcm is bad or could the remotes be bad? Seems like if its going into programming mode the bcm is ok any one have any ideas. Thanks
Old 01-24-2014, 07:55 PM
Pushrods4life's Avatar
I would try the remote first befor getting a bcm because if im not mistaken they need to be re-programed so I would go the cheaper route for now , hope this helps
Quick Reply: bcm help 2000 T/A
