Progressive controller help
Thanks in advance. New to nitrous. Bought the 78mm plate kit from N20 Outlet. Great kit btw! I haven't hit it yet cuz I want to know how to have my Edelbrock progressive controller setup. It's an M6 with a ls7 clutch and S60 with a spool and 3.73's. I've got full boltons MSD digital window switch and efi live cos5 Let me know what you guys think.
Garrett thanks for replying. I'd like to know a few things actually. First id like to see if someone would help me setup the progressive controller as car as delay, start % and end %, build time etc. Like a sample based on my mods. Second, I want to know how the window switch (if set at 3000 on and 6000 off) knows not to turn on the nitrous if I launch at 4000 rpms.
Ls1tech & Truck Sponsor
-Garrett
I plan on starting with 100, then move on to a 125/150. I have 255/60/15 Mickey drag radials. I'll be buying some bias plies after I wear out the mickeys though. So I shouldn't install the WOT switch on the throttle body? Thanks btw for the replies.
-Garrett
Start out at a lower percentage(let's say 30%) and ramp all the way in to 100% over 1.5 seconds. If you're able to hook that then start working the starting percentage up and the amount of time to 100% down. If you cant hook it at that setting, obviously go down with the starting percentage and raise the amount of time. You will find the sweet spot where the car will hook and lay down all of the power as fast as possible.
Thanks Brandon and Garrett. So is it safe to say that pretty much anyone who is using Nitrous with a manual car has the WOT switch mounted at the clutch pedal INSTEAD of the throttle body. Sorry its just I want to be clear because my WOT is mounted on the throttle body, my msd digital window switch is set at 3k on and 6k off, and I launch at 4k rpms off the line, I just want to be safe.
Great info and help from both of you. My Edelbrock progressive controller has a delay. How much delay you think I should start with?
Brandon check P.M. please.
Doesn't the edelbrock controller have a built in window switch and an input for the TPS on the throttle body? The NOS launcher I use has all that stuff built in.
