how will it run? with cam? please
Old 01-27-2014, 09:10 PM
criticalx's Avatar
Default how will it run? with cam? please
96 trans am has frash lt1 with 10.6 to 1 cr ,cc305 cam, stock stall, stock manifolds , 3.42,ram air system off ws6 car, no cats and cat back flowmaster and dr. what will it run like in 1/4? I plan on getting lts, ory and 3200 stall
Old 01-27-2014, 09:27 PM
1994Z28Lt1's Avatar
I would guess 13.5 (depends how you hook) at 105 mph those stock manifolds are killing you
Old 01-27-2014, 09:43 PM
NewOrleansLT1's Avatar
13.3 @105
criticalx's Avatar
what about after I get long tubes and off road y pipe?
Old 01-27-2014, 09:44 PM
95mysticta's Avatar
Why would you go to the effort to build the motor without headers and then ask for advice how it will run? Rather then get flamed why not just buy headers and then ask for our opinion. Id say when all said and done it could likely be mid to high 12 sec car if setup properly.
Old 01-27-2014, 09:53 PM
criticalx's Avatar
well I just built the motor.. its third motor in a lil over yr.. last two I bought put in didn't make it long.. one made it 4k miles spun rod .. other made it 600 miles put a rod though oil pan.. going down the high way 65 mph.. so done this one right built motor myself and running a lil low on money after ..
and want to make sure this one holds up..
Old 01-27-2014, 10:01 PM
Dude you must be buying salvage yard engines. Am I right? But anyway with headers, 3200 stall, and tune it should run mid 12's
Old 01-27-2014, 10:12 PM
criticalx's Avatar
yea one was from a salvage yard.. my brother works for.. when I got car it didn't have a motor and car was give to me.. so I got a deal on motor.. tried it.. failed.. let car set seven months.. my dad give me a motor out a car he had bought.. it run good but car was a hack job.. so wouldn't stay running.. I been fighting with my self over putting money in this car or in my ls1 Camaro.. ls1 runs great but its at 190k so its on borrowed time..
Old 01-28-2014, 01:15 PM
nitrous2fast's Avatar
12.5 @ 130 with an amazing tail wind....
Old 01-28-2014, 08:07 PM
englundjd's Avatar
it should really be closer to 11.5:1 compression but it'll be a fun street car regardless... get rid of the flowmaster tho... they flow like crap.
Old 01-28-2014, 11:59 PM
Catmaigne's Avatar
More cam, more compression, more exhaust flow, higher stall. Your current setup is half baked and needs MORE EVERYTHING to be a screamer.
Old 01-29-2014, 12:05 AM
RedLT1Z's Avatar
You are definitely choking that thing. I wouldn't worry about the cam you can make decent power out of the cc503 with the right setup. Get some nice LT's and a decent stall on it and it will be a night and day improvement.
Old 01-29-2014, 07:39 AM
myltwon's Avatar
he said cc305 not cc503
Old 01-29-2014, 08:37 AM
criticalx's Avatar
I'm wanting it to run best with cam and compression I got. . My dad has 96 trans am with cc503. so wasn't gonna
Use it. Just want it run good
Old 01-29-2014, 09:07 AM
RedLT1Z's Avatar
They are pretty similar. 503 has more intake duration and slightly less lift. 503 should make a little more power but not significant.
CCA-07-305 --- 220@ .510/ 230@ .510 (1.5RR)--- 114 LSA --- 1500-5500
CCA-07-503 --- 224@ .503/ 230@ .510 (1.5RR)--- 112 LSA --- 1800-5800
Old 01-29-2014, 09:33 AM
bowtienut's Avatar
They are pretty similar..
Not even close. Just looking at the duration and lift numbers tells only a small part of the story. Completely different lobes. The CC305 is a mediocre cam for a mild blower setup; poor compared to the 503 for NA.
Old 01-29-2014, 09:36 AM
Catmaigne's Avatar
Less intake duration and a wider LSA. It's pretty much as mild as a hotcam. The 503 still has an edge on it but you should go even bigger than that because you have an A4. I went with a 503 in my car because I have to deal with cam surge in gear with the M6. You don't have to worry about that if you have a decent sized stall because the trans is doing all of the work for you. I think the 306 would be more suited.
Old 01-29-2014, 09:50 AM
criticalx's Avatar
So tell me how much power lose?
Old 01-29-2014, 08:26 PM
criticalx's Avatar
after looking around with stock heads.. I see the cc305 running about the same number as the cc503.. 108-114.. why everyone think the 503 is so much better but I cant find the big deal?
Old 02-05-2014, 11:02 PM
criticalx's Avatar
ok got long tubes headers and ypipe put on car.. what size stall?
Quick Reply: how will it run? with cam? please
