LS1 T56 clutch problems. please help!
Old 01-27-2014, 10:18 PM
Z28trulove's Avatar
Default LS1 T56 clutch problems. please help!
OK so one day I'm driving my 2000 Z28 down the road and its hard to get into gear. Slowly over time it became worse and now it won't go into gear at all. I bleed the system with a mityvac by putting the nozzle in the hole at the bottom of the clutch master cylinder ran the hose to the bottle and then hooked the bottle up to the cup. I pumped it up to 10 and pumped the clutch a little, lots of air came out and it cleared up the problem. I went around the block and bam, hard to shift again and the pedal is light with a lot of dead space. But if I "dribbled" the pedal in the dead space it seemed to fill up the hydrolics and it would shift a little better. So I parked it, over the next few hours install new master cylinder and bleed it. Still won't go into gear...
What the Hecks going on here? I don't know what I'm doing wrong.
Old 01-28-2014, 03:13 PM
Z28trulove's Avatar
Does anyone know anything about this?
Old 01-28-2014, 03:30 PM
ls1guy1968's Avatar
Is there any leaks in the hydraulic line that could be a factor
Old 01-28-2014, 04:11 PM
(SS)'s Avatar
What kind of master cylinder to you put in it?adjustable?
What shifter do you have?
It could also be your throwout bearing.
Old 01-30-2014, 08:41 PM
Cameronsc5's Avatar
I used a mityvac to bleed mine and it didn't get all the air out. Get a buddy and bleed the crap out of it. If it some what fixed it after the master install I don't think it would be the throwout bearing.
Quick Reply: LS1 T56 clutch problems. please help!
