Popping Noise When Turning
Since I got my 02 ss there had been a popping noise when I made turns occasionally. Last night it turned into a rather large noise followed by the car seeming to drag ***. I parked her and did a quick visual inspection with ye olde flashlight underneath thinking something was caught in my wheel or I had a flat. Neither of which was the case... I'm getting suggestions leading to possible shock failure or rear differential problems. I have yet to switch the diff fluid since purchasing a month ago. Any ideas fellas ?
I'd get the diff fluid changed out ASAP. As ULTIMATEORANGESS said, if it were the rear end completely failing, it would have a whine/howl sound coming from it all the time - not just when you turn. To me this sounds like the fluid is bad causing some binding in the turns, and fresh fluid could do wonders.
As weak as these rears are, I'd recommend fresh differential fluid whenever someone buys one of these cars. Very cheap insurance, and it eliminates a lot of possible issues to give you a really good look at what kind of shape the 10-bolt is in.
I'm going to change the fluid ASAP, but I had a friend watch me drive around and said my car was sagging on the back right side which leads me to believe that is the shock.
