S10 9" Ford BUILT, COMPLETE, All New, NC Located
Category: Accessories
Price: $1600
Location (State): NC
Item Condition: Brand New
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6, LT1/LT4, Small Block, Big Block
LS Engine?: Fits LS Engine
ALL NEW NEVER RAN. Stored in my damned living room as many members can attest to... The calipers aren't clocked/mounted in some photos(just how it sat for pics), and ill also include the fittings and S/S braided brake hoses.
Overall width from spring perch center to center is 38.5", and from rotor hat face (wheel mounting surface) to rotor hat face is 51.5".
I had it built to these specs to run under a NONtubbed s10 with an inch less backspace with each wheel for a better look due to a deeper wheel barrel while bolting into stock location.
Also, FYI, for anyone interested those measurements would be very close for working in a minitubbed 1967-1969 Camaro or 1968-1972 Nova with DSE 1-3/4" offset shackles. Also-believe the 55-57 Chevy shares the perch width, but guessing they too would require minitubbing..
-Complete Custom built and assembled 9" Ford rear consisting of:
$Heavy duty thick wall housing
$Narrowed 2" to run 1" less backspace for deeper wheel barrel under stock wheelwell under S10 but can surely be modified or parted out at this price..
$Jackpad and drain plug
$Powdercoated Satin Black
$Billet new ford big bearing housing ends
$ARP center to housing studkit
$New Ford Racing T-bolts and billet aluminum retainer plates
$Moser Nodular Iron 5/8" bolt PRO-N Case Clearcoated
$Billet Daytona pinion support
$Strange Engineering 40spline Gundrilled axles and bearing kit
$40spline Billet steel full spool
$Billet 1350 pinion yoke and u-bolts
$Timken bearings throughout
$Motive Gear 3.70 gearset lightened 3#'s from backside of ring gear
$ARP everything
$Wilwood black Pro Drag drilled rear disc setup with dyna forged calipers
$Strange CrMo 4" 5/8" shank screw in wheelstuds
$1600 PICK UP ONLY, and FIRM AS HELL
Thanks Tech
I just finished a 6.0 s10 for a customer and he needs a rear ill surely let him know bout it hes already got the caltracs and springs just needs good rear I got 1st dibs if u still got it? also where is apex nc im n orangeburg sc 29115 willing to meet ?
Fwiw-this rear should easily handle the duty as it was assembled to be 4digit RWHP capable. I have one guy in front of you as he pm'd me not even 15min after listing it, and we're trying to work out the details, but you are second in line and one more behind you. I honestly don't have the time to get away from Raleigh as of late which is why I priced where I did and requesting picked up..
