02 TA Procharged
I have the inter cooler mounted and and all driver side piping installed. I will be mounting the head unit today as well as the passenger side piping. Think it would be ok to go ahead and install the Racetronix hotwire and pump with out tune? I have 60lb injectors but I wont put those in until I get to the tuner. I could prolly finish today but I am still waiting on my Super damper to come in the mail.
what dyno will it be on.
what is your compression ratio.
what cubes.
what is your pulley size
crank pulley size.
automatic or 6 speed
10 bolt or 9 inch
what size cam.
running any methanol?
start there and can get you in the ballpark.
allout made 571 on 5.5 psi
i made 600 on 9psi.
alchemist made 750+ on 16 with a boost leak and conservative timing.
we were all d1. but that p1 should get you to 550 to 600 easily. enough to max out that single racetronix here soon.
what cubes.
crank pulley size.
10 bolt or 9 inch
what size cam.
i made 600 on 9psi.
what cubes.
crank pulley size.
10 bolt or 9 inch
what size cam.
i made 600 on 9psi.
what cubes.
crank pulley size.
10 bolt or 9 inch
what size cam.
i made 600 on 9psi.
10.5/1 compression
347 ci
6 speed
10 bolt
228/230 cam
no meth
Yes still in Hawaii. Been here since 2008. I leave in couple months for the main land. That Hobby shop i was at is the one on MCBH. I dont plan on any more than like 8psi. When i get to where im going to turn it up a bit.
LS1Tech Sponsor
Did the balancer show up yet? Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
