69 Camaro G8/6L80e Swap *Build Thread*
Old 02-02-2014, 11:08 PM
Hybrid 69's Avatar
Default 69 Camaro G8/6L80e Swap *Build Thread*
My Dad and I restored this car about 13 years ago. We decided it was time to step into the new age. The old set up was a 80's 350 bored .30 with the Edelbrock performer RPM aluminum heads and intake. Behind it was a 700r4 tranny with 3.73 gears.
Old power plant
We decided on a 2009 Pontiac G8 6.0L (L76 option) with a 6L80e tranny both with 25k miles on them. Purchased it from a salvage yard in North Dakota called Kens Auto. It came with a 6 month warranty from the time it is first started up.
New power plant
We have a friend doing the swap for us, his user name on here is (moreengineering) he's done 3 LS swaps in his own cars (Chevelles). The G8/6L80 and the Camaro has thrown him some curve ***** along the way but that's expected I guess. We started the swap in March of 2013. I'd say were about 60% done.
The car is in Georgia with my Dad, I live in Florida now so it's 8 hours away from me. I've been able to make it back 4-5 times this year so I've helped moreengineering when I was there. I hate not being there for the entirety of the swap, but I stay in constant contact with him and I'm in charge of all the parts ordering.
The car was an base model V8 from the factory, didnt have the original motor in it and wasnt restored back to stock when we did it 13 years ago. We're not purest and the cars not original so we had no problem putting a newer LS motor in and doing what we have to in order to make it fit. So far so good, worked through several hurdles. This is the set up so far
Parts List:
-2009 pontiac G8 6.0L L76 option with the 6L80E tranny
-Mast motorsports ls swap oil pan
-Dirty dingo LS swap adapter plates
-Wiring harness rework by Speartech, kept the DOD, added a tap shift box
-We kept the factory K member mounts (short and wide I believe) but moved them up about 3/4" in an effort to keep the alternator and the a/c compressor in the low mounting position
-Used 2000 S-10 with a 4.3L motor mounts, Energy Suspension poly urethane PN: 3.1144
-Used a 69 V8 with a turbo 350 tranny mount,Energy Suspension poly urethane PN: 3.1108
-Had to notch the k member for the alternator to stay low
-Used a 2000 Camaro with a V8 radiator and upper and lower radiator hoses bought from O'rielly Auto
-2000 Camaro with a V8 efans ordered from Rock Auto PN: 620634, electric plug for the fans (2) PN: PT304
-Spectra factory replacement fuel tank PN: GM32BFI, set up for fuel injection, ordered an extra fuel pump (I've heard they are weak and tend to fail around a year or so..) PN: EP381, both from Rock Auto as well. Had to add a vent to the tank though, out the top at the center. See page 6 for details
-moreengineering made a custom tranny cross member, he used 1"x2" 3/16" wall tubing. 1/4" plate was welded on the ends to allow it to bolt in
-We plan to keep the aftermarket auto meter gauges we have from the original restoration. We will have to get an electronic speedo and temp gauge due to the ones we have being mechanical
-Keeping the factory G8 exhaust manifolds for now, no cats
-Using a 2010 Camaro 6.2L aftermarket intake CAI, we'll cut the bolt in style MAF area and replace it with the in line style MAF for the G8
-Using a 2010 Camaro 6.2L pick up tube PN: 12570787 and dip stick PN: 12570788. The G8 came with it in the oil pan, our aftermarket oil pan won't work with it entering through the side of the pan. Had to remove the dip stick plug from the passenger side of the block.
-In order to convert the non slip yoke output shaft of the 6L80 we bought the follwing: Adapter from The Driveshaft Shop PN: GTOPL-2 which includes PN 3-2-119. The first is an adapter that bolts to the output of the 6L80, this is threaded to allow the second PN to bolt to it. PN 3-2-119 is a spicer 1350 flange. For the slip yoke pieces we went to Denny's Driveshafts and got their PN: 3-40-1621, the male side of the slip yoke and PN: 3333586, the female side of the slip yoke. This set up will be welded to a 3.5" driveshaft. We also bought a 1350 style greasable U-joint as well
-2000 Camaro with a V8 power steering pump from O'reilly Auto. See "issues" below for why we ditched the stock G8 P/S pump
-Lokar 6L80 24" tranny dip stick from Summit
-Went with a Sanden 508 with 7 groove compressor PN:191-101 (summit racing I think) or SD5H14. Also went with the vintage air PN: VTA-04808-VMA condenser / dryer kit
Issues so far:
-Cut the tunnel out, see pic, we did an "I" cut originally but the tunnel metal was so hard to work with we decided to cut it all out. We will rework it off of the car (bending and what not) then reinstall back to the orginal cut lines (at the floor pans) hopefully with a filler piece added in the middle at the top. This has yet to be done/worked out but this is our plan. The tunnel needed to be wider for the most part but will prob need to be slightly taller as well.
-Notched the k member for the alternator, our choice to try and keep the low mounting position this way we can keep the factory engine cover
-At the final motor install and the reinstallation of the P/S pulley we realized it was too big. it was real close to the control arm with it's was a 6" o.d. pulley. He ended up swapping it out for a 2000 Camaro with a V8 P/S pump. aparently the G8 P/S pump had a weird output shaft size and smaller pulleys were hard to find to replace the 6" o.d. one. The 2000 Camaro P/S pump mounted in the stock location and has a more popular output shaft. He was able to find a smaller P/S pump pulley that would work from a 2000 chevy with a 3.1 V6 motor. It's worked out and we have the control arm clearance now...
-We are still deciding what to do with the A/C. One option is to relocate the A/C compressor to the upper mounting position using Holley LS swap brackets and a Sandan aftermarket compressor. The G8 compressor will not work with the factory mounting brackets or the old AC system I have found out after researching it a good bit. I will probably need to get a newer style condensor if we go this route.
-Figuring out how to convert the fixed yoke style tranny (the G8's and new camaros have independent rear suspensions) to a slip yoke style took a lot of research. Finally found the adapter option on a 67-72chevytruck forum. We have all the parts listed above but have not installed them yet. I also found the tail housing conversion option but we didnt want to go that deep into the tranny and the adapter option was right at the same price
Still To Figure Out:
-How to get the factory G8 A/C compressor to mount low without the orginal bracketry. If and how the G8 A/C compressor will work with our original Camaro evaporator box. What all else I would need to get everything plumbed and set up correctly.
-Shifter, thinking I'm going to go with a stock G8 shifter so we can take advantage of the manual mode. Still have to find one and mount to the tunnel once we make it
-I'm sure there is something I'm forgetting..
Here's some pics of the progress:
Mast motorsports oil pan, holds 5.5 Quarts
Mounted up
Dirty Dingo adapters and Energy Suspension 3.1144 poly mounts
First of many test fits
Like I mentioned ealier we've been working on the swap since March of 2013 and this is where we are now. Slowly but surely we'll get there. Thanks for looking, feel free to ask questions I'll help others anyway I can. I'll post more pics as progress is made or upon request. If anyone can help me with my A/C questions (see above) that would be great!
Thanks!
Old 02-02-2014, 11:10 PM
Hybrid 69's Avatar
Default Pictures Continued
Good side shot of the new oil pan
Marked lines for where to move the motor mounts up on the k member, moved them up about 3/4" on each side
Cleaned up engine bay for paint. k member notched for Alternator
Repainted Engine bay
Motor in place for the final time hopefully..
Thinking the hood should clear
Evaporator box clearance
Gear box clearance
Alternator clearance at the k member after notching
Cutting time
"I" cut
About where it need to be height wise
No turning back now..
New tranny cross member
Mounted up
No low hanging pans here..
Motor mount shot
New E fans
Radiator and E fan mock up
With 2000 Camaro hoses, went right in
Lower Radiator hose
Stock G8 P/S pulley 6" o.d. before we swapped it out for a 2000 Camaro P/S pump with smaller pulley
2010 Camaro K&N CAI
Old 02-02-2014, 11:27 PM
1989GTA's Avatar
Signing on for the build. Looks good. I put my A/C compressor up high on the passenger side.
Old 02-03-2014, 12:06 AM
billyflantos's Avatar
x2...
Old 02-03-2014, 07:08 AM
Hybrid 69's Avatar
We hope to have the car done in the next few months, cant wait!
Old 02-03-2014, 08:41 AM
Hart_Rod's Avatar
Nice build! I did a similar setup in my 68 C10 (13' LS3/6L80). Here's my build thread. It might help you with some of the issues you have or will have LOL!
http://67-72chevytrucks.com/vboard/s...358692&page=17
https://ls1tech.com/forums/conversio...e-tvs1900.html
Rob
Old 02-03-2014, 09:28 AM
Jimbo1367's Avatar
Hybrid 69,
Great write up. Thanks for sharing. Thats a gorgeous car. Any chance of getting more pics of the car the next time you go back to work on it? I bet giving the 700R4 trans and 3.73s it was plenty quick. A gear change might be in your future with the 6L80's first gear and 3.73. 1st gear will be useless. LOL. Forget about WOT from a dead stop.
You might want to do a SEARCH on retaining the DOD. There has been many instances (several forums) of the DOD lifters failing on low milage (under 100K) stock cam/engines. You might want to consider AlenGroveComponents http://www.alangrovecomponents.com/LS.htm for a aftermarket Sanden compressor low mount setup. The "truck" setup (3rd down on link) will work for the VVT cammed motors. FWIW
Old 02-03-2014, 10:23 AM
superdave84's Avatar
Awesome. I had considered the L76/6L80 combo myself, but I found a price on an LS2 I couldn't pass up. I love the factory engine cover too!
Old 02-03-2014, 11:21 AM
Hybrid 69's Avatar
What was on this page, I didnt see anything relevant. You may have been referring me to the whole thread? I think that's the case, gonna take me a while to get through all 51 pages
Rob
Thanks for the links, very nice build, I just posted a few questions for you on the second one. What was on the page 17 you sent me, I didnt see anything relevant? You may have been referring me to the whole thread? I think that's the case, gonna take me a while to get through all 51 pages
Old 02-03-2014, 11:32 AM
Hybrid 69's Avatar
Hybrid 69,
Thanks for the kind comments, its been a project for sure. Let me see what other pics I can find of the car. It was restored so long ago, I'll round up some for ya. The old motor/tranny combo was good. It had been in the car 10+ years even though we hadn't driven it a ton. Had oil leaks, needed new headers, needed a water pump, alternator wasnt charging like it should and we had never hooked the A/C up (Needed a new compressor). We priced a serpintine belt set up to take care of all of this and knew we would one day also want to do fuel injection. Both of those were close to the cost of a complete take out motor so we decided to go that route instead. Just wanted some new technology and better mpg's to boot.
I agree on the gear swap, were gonna see how it does. Shoulda planned a little better because we just put the 3.73's in when the 700r4 went in 6 or 7 years ago... It ought to do some nice burn outs though
Were keeping DOD at this point, I will reasearch it though. Maybe something to consider deleting down the road. Thanks for the heads up, I hadnt heard that..
Thanks for the AlenGroveComponents link, I'll check it out.
Thanks man, hope we can keep it as planned!
Old 02-03-2014, 07:46 PM
Hybrid 69's Avatar
Default More pics
Hybrid 69,
Door panel shot. We used 2000 a Camaro buckets when we did the original restoration. Marine grade vinyl was used for the door panels and seats. Recovered the stock back seat with the same material. Stock center console
Auto meter 5" Tach and Speedo, 2 1/16" gauges in the center console
It's sad but these are all the digital photos of the exterior/interior that I can find right now..
Old 02-03-2014, 08:43 PM
Hart_Rod's Avatar
How tall of tire are you going to run in the rear? I'm running a 31" with 4.11 gears and love it! At 70, I'm right around 2K rpm.
Old 02-03-2014, 09:15 PM
Hybrid 69's Avatar
Not sure at the moment. Big brakes and wheels are in the cars future as well once the motor swap gets done. I'd like to do at least 17" rims all the way around maybe 18"s. Still have to research what I can fit on the car without too much modifications.
Old 02-09-2014, 08:05 PM
Hybrid 69's Avatar
Do any of you know of a build where a car or truck with factory ac was set up with a new style ac compressor? I have yet to find one with my research. Someone out there has to have done it. Need to know if it will work and what all I'll need to make it work. I can only find builds that used vintage air systems. Help please!!
Old 02-09-2014, 08:17 PM
Carguy8888's Avatar
Wow good luck, along for the ride.
Old 02-10-2014, 08:36 AM
Tommy69z's Avatar
I installed the LT1 evap in my factory AC box, upgraded to a fan to move more air, and ran the 97 LT1 compressor, never was happy with the performance, I am about to swap in an L92, and I plan to smooth the firewall and put in an AC setup as money allows...
Old 02-10-2014, 01:14 PM
Hybrid 69's Avatar
So you replaced the factory (old) evaporator with the LT1 unit in the factory box, then hooked it all up to the factory LT1 compressor. What all does it take to make this work? LT1 condesor, dryer...? Did it just not cool like you wanted or what, explain more if you dont mind? Once you smooth the firewall you'll be going with an aftermarket set up? Vintage air or what?
Old 02-10-2014, 01:34 PM
Tommy69z's Avatar
Yes I plan to go aftermarket...it just did not cool the car well. It has been well over 10 years, and several since it had the LT1, but seem like it took minimal work to get it to fit inside and seal it properly. I used all LT1 components except I used the factory 69 condenser. it never flowed enough air I think to work properly.
Old 02-10-2014, 02:01 PM
Hybrid 69's Avatar
Ok, that helps. Yeah, I've heard to use a new style condensor for that reason. I never thought of using a newer style evaporator in the old evaporator box, thanks for the idea.
Old 02-10-2014, 03:34 PM
Chevy Kid's Avatar
Check with Classic Auto Air. They do retrofits and can help with 134a transition.
Quick Reply: 69 Camaro G8/6L80e Swap *Build Thread*
