Brake Line Install now. HELP
3 questions. I am trying to get the front brake line off. i have it off the caliper but i can not get it off the frame side. before i cross the point of not return and cut the line and try to use a socket to get it off what suggestions do you have? i can not seem to get a grip on this thing to move it.
also my racing brake kit only came with 2 bolts and 4 washers is this right?
and is the correct line for the front one of the long ones?
I hit original factory tightened flare fittings with PB blaster and let them soak. I use a closed end box wrench wherever possible. I use professional flare wrenches and not cheap craftsman models that flex and round flare nuts. And finally, I always try to tighten 1/16 of a turn first, before backing the fitting off, puts stress and wear on opposite corners of flare nut and reduces the chance of damaging the nut.
thanks guys. i got it while you all where posting. i feel like a moron fighting with that thing with the ******* clip still on. popped the clip off and it was a breeze. i already had it soaking in PB blaster. i have the provided copper crush washers on it. i only did one line tonight that was leaking like a hose. now i at least feel comfortable driving it to my buddies house with a lift to finish it up soon.
I called racingbrake and they are going to send me the additional bolts and washers.
There should be four bolts and five lines the right rear should have a crossover brake line. What is the solid aluminum ended line you're talking about?
Use this thread for reference
https://ls1tech.com/forums/cadillac-cts-v-2004-2007-gen-i/1446040-goodridge-stainless-steel-brake-line-installation.html
This is what you're supposed to get:
The people that were around when Luke @ Lindsay first introduced the UUC brake line kit have mostly passed on, but a couple still remain (including thebigjimsho and Junior1) on the Cadillac Forums. I put up a general post and shot Junior1 a PM. If he responds, I'll let you know.
