External pump for "street car". Need help
Old 02-04-2014, 03:39 PM
a.white86's Avatar
Default External pump for "street car". Need help
People keep telling me to swap my 00' SS to Nasty Performance sumped tank and run a Magnafuel 4303 but I've read they have a max run time of 45 minutes before overheating and dropping pressure.
Camaro is getting a 408", billet s480, 4L80, 130lb ID injectors. -10 feed and -8 return lines are already here.
What do I do? I wanna drive the car to work sometimes, I definitely don't drive it much, but what IF I do want to?
Old 02-04-2014, 03:57 PM
ws602's Avatar
Get the pro touring tank from nasty the pump is mounted internally .
Old 02-04-2014, 05:03 PM
The Beast's Avatar
The 45min run time is for the 4100 and 4700 series pumps, the ones that don't run the fuel through the entire pump body to cool it. I've personally driven my car over 2.5hrs nonstop and had zero problems and zero pressure drop. Highly recommend the 4303
Old 02-04-2014, 05:05 PM
a.white86's Avatar
Ah ok thanks Beast. I could deal with that!
Old 02-04-2014, 06:28 PM
samdogmx's Avatar
Holley 12-1800 is a good external
Old 02-04-2014, 07:28 PM
a.white86's Avatar
I'll look that up sir, thanks!
Old 02-04-2014, 07:56 PM
a.white86's Avatar
Anybody using this? Someone just told me that they aren't impressed with really anything Holley has right now. But is anybody using the Dominator pump?
http://holley.com/12-1400.asp
Old 02-04-2014, 08:14 PM
73turbo53's Avatar
X2 on the holley, it is second to none
Old 02-04-2014, 08:24 PM
a.white86's Avatar
Is the one he's referring to above one of the dominator ones?
Old 02-04-2014, 08:49 PM
a.white86's Avatar
I've picked one out.
Holley Dominator 12-1800
Old 02-04-2014, 09:00 PM
Unstang's Avatar
I've seen good stuff out of the Dominator pumps. I have a 12-1400 that I put in my car at the end of last season. I ran it for around 50 miles & decided to redo my fuel system, so going to step up to a 12-1800.
If anyone is interested in the 1400, shoot me a PM.
Old 02-04-2014, 10:37 PM
itsslow98's Avatar
I drove my cobra home from NC(6.5hrs) nonstop with an aeromotive eliminator external pump on 100% duty cycle and never had an issue. Ive taken it to and from Ocean City which is 3hrs each way multiple times without any problems as well.
Old 02-04-2014, 11:24 PM
a.white86's Avatar
Any reason for the upgrade? Or just to support more power, period?
Old 02-05-2014, 04:42 AM
samdogmx's Avatar
how much power & what fuel? The 1800 has been proven to around 1000-1100 on E85
Its also whisper quiet.
Old 02-05-2014, 07:36 AM
Man-Crush Warning
Shownomercy's Avatar
I run the 4301 and its loud as hell but, never had an issue with driving around last summer. Lots of stop and go summer traffic as well.
Old 02-05-2014, 07:55 AM
runsfromdacops's Avatar
Just do twin bosh 044s they do very well at high pressures and are super quite
Old 02-05-2014, 09:36 AM
dmaxvaz's Avatar
you have dyno sheets to prove the 1000-1100 on e85? just curious, because i have this pump, and i was going to go to biggger injectors and dont want to run out of pump. i have the holley 12-1800, FIC 1000s, -10 feed, -8 return. made 801 rwhp with this setup
Old 02-05-2014, 11:39 AM
Forcefed86's Avatar
Depends on the base pressure and boost. The more pressure the less the 1800 will flow. 044's seem to be the choice of most that want a reliable inline "race pump" that performs well at high pressures. They are $125 shipped each new. Could almost buy 3 for the price of the holley.
Old 02-05-2014, 07:36 PM
a.white86's Avatar
Im unsure on fuel pressure I'll be running.
Old 02-05-2014, 08:05 PM
LSXMATT's Avatar
Also heard good things about the Holley pumps, considering one for my 67 c10
Quick Reply: External pump for "street car". Need help
