What shot can a stock bottom end LS3 handle
I have a 2011 Camaro M6 with a stock bottom end, but have a VR Kaotic cam and all supporting mods for the cam. 1 7/8" TSP headers with straight pipe exhaust. I'm looking to go with a 150 shot but not sure if the engine will hold up and also if I would need to upgrade the fuel pump. Any help would be appreciated!
Nitrous Outlet plate 82N jet on 93 oct.
I'll be using 91 oct., and possibly going with Nitrous Outlets plate system. Will I need to upgrade my fuel system at all? Or use a dedicated fuel system?
You could easily spray 150 on the car with the proper saftey parts to go with the kit. Hell you could probably sray 200!! I sprayed 150 on my LS1 and never had a problem with it hurting the motor. Transmission held up for a while but eventually shredded. Spend the money and get the saftey parts to go with it and you will easily be able to spray 150!
All depends on the tune-up. Then you have to worry about rings butting. I'm putting 400+ through a stock bottom end ls6. The only thing I did was re-gap the rings. Oh, I put arp rod bolts in it too. Everything else is stock.
Stock fuel system most likely would need upgraded or install a stand alone for the nitrous. LS3 stock bottom should be fine with 150 on top of your mods. Pull timing, colder plugs, etc.....
