Fuel System Required?
Old 02-08-2014, 09:27 AM
MidnightDynamite's Avatar
Default Fuel System Required?
Couldn't find anything in search bar so I figured if give this a shot. When looking at supercharged specifically whipples it said fuel system required or something along those lines. What exactly would need to be done to a pretty much stock ls1 to handle say the W200AX twin screw from whipple
Old 02-08-2014, 08:34 PM
LS1TECH Sponsor
Lonnies Performance's Avatar
Up to approx. 550rwhp, a Racetronix pump/hot wire kit will take care of your needs.
Does you kit come with injectors? If not you will need some.
On a stock LS1 this is about all further you will go power wise.
If you plan on more power with a modified engine, you will then need additional fuel system components.
I can set you up with whatever fuel system components you are looking for.
Feel free to give me a call.
Old 02-08-2014, 08:53 PM
Alright man! Thanks!
Quick Reply: Fuel System Required?
