Looking for a good drive shaft
Old 02-09-2014, 07:51 PM
Ls1onLsd's Avatar
Default Looking for a good drive shaft
Wondering whats a good drive shaft thats not too expensive. Im seeing them for around the $150 range. Also looking for a good set of U-Joints.
Going in an 01' Camaro Z28 with a 4L80e transmission and stock 10 bolt rear end (for now)
Thanks
Old 02-10-2014, 12:08 AM
GiggleJuiced_SS's Avatar
Curious on why you're upgrading the driveshaft? A good driveshaft isn't cheap. U have a A4 so it will last alil longer. I run a PST driveshaft ~480 bucks. I don't think u will find a driveshaft for that price range but you could upgrade your u-joints for cheap if you wanted.
Old 02-10-2014, 01:08 AM
20TA02's Avatar
Give Carl at CRP a call, I ordered a Strange Engineering driveshaft through him and it wasn't too expensive at all.
Central Racing Parts
316-299-8427
Wichita, Kansas
Old 02-10-2014, 01:26 AM
Super Hulk Smash
JakeFusion's Avatar
The Driveshaft Shop can do a 3.5" aluminum that can connect to the stock rearend and send you the appropriate U-Joint if you want to upgrade to a 12-bolt down the road. I went with them because they have the equipment to actually dynamically balance their driveshafts upto 9000 RPM.
Old 02-10-2014, 08:45 AM
LS1Tech Premium Sponsor
ssvert99's Avatar
Thanks
Chances are your oem driveshaft with a different yoke and a conversion u-joint will work. Give us a call and we can get you the details and other options as well.
Old 02-10-2014, 10:41 PM
Ls1onLsd's Avatar
I meant the $150 range, as far as used, not new. I have over $11k invested and Im sure I'll be upgraded the rear end to a 12 Bolt/9" in the future, but for now, I dont want to buy anything and have to rebuy it later, meaning Id like for the U-Joints to be universal with whatever rear end I end up going with. Im hearing "Spicer" makes some good ones but I know theyre solid also. This will be a weekend cruiser/street-strip car, not driven very often.
Old 02-11-2014, 01:19 AM
Personally I would wait till you change the rear end to change the driveshaft that's what I did anyways.
Old 02-11-2014, 02:49 AM
Undertow74's Avatar
I would wait then until you decide on what rear end you want to go with. The drive shaft is going to be a different length if you choose a 9 or a 12 bolt.
Old 02-11-2014, 10:09 AM
ssvert99's Avatar
Spicer does make good u-joints, but until you change out the rearend and really abuse the car the reared will most likely fail before the u-joints. The oem driveshaft has enough slip left to accept the slightly longer 4L80 trans, so just get the correct yoke and u-joint for now. We have all the right parts at the best prices... give us a call!
Quick Reply: Looking for a good drive shaft
