70 c10 5.3l swap
Old 02-09-2014, 09:25 PM
cr250r's Avatar
Default 70 c10 5.3l swap
Hi guys im going to be doing a 5.3l swap into a 70 c 10 with my tax return what kind of mounts are you guys using? Thinking of going turbo and going to an 80e with a tci trans controller
Old 02-10-2014, 02:38 AM
Revoroller's Avatar
Cpp makes mounts, I built by own. Go check out 67-72chevytrucks.com and refer to the lsx swap section. All the info you need man
Old 02-10-2014, 06:58 PM
Hart_Rod's Avatar
CPP stands and Dirty Dingo sliders...
Old 02-10-2014, 09:00 PM
6.0 1955's Avatar
I used 6 cylinder stands and cheap ebay swap mount plates with original 6 cylinder motor mounts. V8 stand position will give you a little more firewall room. I also used an 04 truck radiator and hoses.
Quick Reply: 70 c10 5.3l swap
