How much oil do you run with?
master of the "jack"stand
I have heard that oil starvation is a big problem with LS1s, especially in high G corners, but I would think hard launches could starve the front of the bottom end. I have heard of guys running as much as 7 quarts with a stock bottom end and stock pan.
How much do you use?
LS1TECH Sponsor
Originally Posted by soundengineer
If you run too much oil you can get a hydraloc situation....BAD BAD BAD...
7 qts with a filter here. If you run AX with 6, you are really risking a rod bearing.
https://ls1tech.com/forums/showthrea...ght=starvation
http://frrax.com/rrforum/index.php?act=ST&f=8&t=1227&
Great links Mitch, I hadn't seen your post until now. I will definitely run more than 6 quarts if I plan on AXing or open tracking. Looks like 7 is a pretty good amount to run.
