torqstorm on a 4th gen 2002 ws6
I bought one of these and have been searching for a thread on a completed system. Haven't found one. Has anyone on here done one?
edit: This is what it looked like when finished 4/2/14:
edit: it took a lot of time and effort to find these parts so...
new brake lines for the abs. Small line only available at napa. Actually it's 2 adapters and 3/16 line. A longer 6mm line can only be found at Autozone.
And you'll need a 1" longer serpentine belt for the accessory drive and this blower belt.
I have never even heard of them until a quick Google search. Seems like a nice Supercharger, just not a very big company. See if you can find some brackets for it and run it.
This isn't my car but what it will look like plus the BOV. I was liery of them because they have no rep yet but there head unit has a LIFETIME warrenty so I 'll give them a chance. Everything in the pic plus BOV with meth and IAT bungs was $2850.
I really like the BOV because instead of the crappy diaphrams that burst this one is a brass piston and O-ring.
From what I gather on there website powerdyne came to them to do a total redesign but backed out so they ran with it since it was there design work anyway
says gear driven on there site.
Housing and cover made from Billet Aluminum for better bearing control
Ceramic bearings
Centrifugal design
Gear driven
Limited Life-Time Warranty.
Self lubricated
Synthetic oil pre-filled from the factory
Billet impeller
Ceramic bearings
Centrifugal design
Gear driven
Self lubricated
Billet impeller
Spoke with Rick Lewis over there, kit is 3900.00 out the door and includes injectors and a KB boost a pump for 2010+ camaros.
There isn't a fbody kit but it's down to 2800.00 with just the head unit, brackets/tensioner, lower pulley spacers and mounting hardware
It mounts on the drivers side and maintains stock powersteering location, requires ws6 hood and you need to delete or ***EDIT*** move your ABS.
Dyno graph attached from a 2010 camaro, not sure what was done to the car though.
Not REMOVE , MOVED forward, rotated, and maybe down a few inches. U people think I'm lieing or something? Wtf
This is the new location of the ABS. No it's not belt driven. No there aren't hamsters in there turning the impeller. No I didn't pay $2800 for just this and that. I got everything in the picture for $2850. Nice BOV, 3" mounting pipe with bungs, air filter, silicone hoses, clamps, fast IAT sensor.
Im very interested in this setup.i wonder if it will fit under a stock camaro hood.called them a few min ago.blower puts out 1150cfm what ever than converts to in lbs a min idk.for me this may be a better solution then building a ac turbo kit for my car since its a street car
its' a local company here in Grand Rapids,Mi. there are a few cars and trucks running around town here that have them and the customers seem happy. I have one that is going on a truck 5.3l that is going into a 84' Malibu.
I got the bracket on today. A lot more trouble than I expected with the power steering. The bolts are tight behind the pulley and for some damn reason there r no access holes. Pump gets moved up and left 1". Necessitates a 1" longer belt. I had to heat and bend the ps line at least 16 times. They should offer a hose. I gotta move that darn abs. A new bracket would have been awesome. I dont know what I will have to do about the radiator hose and ps cooler. Surely this isn't the first 4th gen torq storm thread.
