LM7 in Mercury
LM7 in Mercury
Hi, i have a Mercury -49 projekt with a Malibu front clip. I believe its from like 1979 or so.
i just ordered a LM7 engine from a Silverado -02.
There is no motor bushings on the front clip and no mounts on the engine.
So, my first question. What kind of engine mounts do you think i should use? Is there som universal kind that is good that will work with my front clip?
More good ideas are welcome!
I had a LT1/4L60 in my last projekt.
I think these mounts should work if you combine them with the stock clamshell mounts that bolt to the frame:
http://holley.com/12613HKR.asp
Andrew
Andrew
Yes, that was my first idea. But then i thought that its unnecessary since i dont have any of them and might have to mount the engine higher or further back in the car.
Hope you get my english...
