Meziere EWP, less than 50 miles
Category: Accessories
Price: $1
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 67-92 Chevrolet Camaro, 67-92 Pontiac Firebird, Front wheel drive vehicles
Location (State): TX
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
http://www.summitracing.com/parts/mez-wp319s/overview/
and this is the optional harness I bought to make it an easier install.
http://www.summitracing.com/parts/mez-wik346/overview/
I also bought a hypertech thermostat that I never installed which was another ~15 bucks.
ALSO, ARP water pump bolt kit I got from summit ~25. Remember its the little touches that stand out.
http://www.summitracing.com/parts/ar...3202/overview/
The harness and relay has been soldered and heat shrunk with perfect length cables left in tact to wire it to the fuse box for ignition, a wire/terminal to the bolt next to it for power and the bolt on the radiator support for the ground. You wire this in about 10 minutes, literally then plug in the harness to the pump. All wires are soldered/heat shrunk and have terminals. Nothing should have to be spliced, all the work is done. It took me 4.5 hours to install it a month and a half ago (because of all the wiring/soldering and terminals) and 2 hours to remove and replace the stock unit today, so with all the wiring left to plug and play.
There is about 825 in this set up, including the pump, harness, ARP bolts and thermostat. I will take 640 obo for it. Again, it has less than 50 miles and comes in the original box with paperwork and everything it came with.
I have been offered more already Don, just hoping to get closer to my asking price.
For those who asked, it does come with the aluminum heater hose block off plates and also comes with the aluminum AN type heater connections. Complete package here! Bump
