Billet Valve Covers Threaded oil cap and Stock Fill Tube?
Old 02-14-2014, 06:52 PM
Patsy57's Avatar
Default Billet Valve Covers Threaded oil cap and Stock Fill Tube?
So I recently purchased a set of Moroso valve covers for my ls1 heads which come with a threaded oil filler cap. I need to put a stock filler neck on it because I want to run a specific breather from RX Performance that I have (1LE)
That being said is there an adapter that will allow me to connect the stock valve cover oil filler neck to the threaded hole in the moroso valve covers?
Please let me know. I have attached some pics of the covers, the filler neck.
Thanks!
Attached Thumbnails Billet Valve Covers Threaded oil cap and Stock Fill Tube?-t2ec16vhjf4ffkswbkgjbr-wqot6nq-60_35.jpg   Billet Valve Covers Threaded oil cap and Stock Fill Tube?-img_20130911_233735_684.jpg
Old 02-14-2014, 08:46 PM
That's MISTER MODERATOR
Paul Bell's Avatar
Looks good! I think there was a work-around for this, I hope somebody posts up. I'm interested too.
Old 02-14-2014, 11:53 PM
Patsy57's Avatar
I thought there was an adapter but I can't seem to find it. Hopefully someone chimes in
Thanks
Old 02-15-2014, 08:21 AM
Patsy57's Avatar
Anyone? Please assist
Old 02-15-2014, 09:29 AM
LPE 403's Avatar
Do you have to use the stock breather? Why not a K&N type? I have Crane Cams billet covers and had the same issue. Used a water neck fitting that screwed right in and slipped the breather over it. Clean too....
http://www.meziere.com/displaycatego...id=244,315,307
Double check your thread size....believe mine is -16. I don't use it anymore as I now run (2) -10 lines to a catch can. Be glad to give ya deal on it if works.....
Old 02-15-2014, 09:41 AM
Paul Bell's Avatar
There's no way you can come in here without telling us about that intake setup you have. We're listening....
Old 02-15-2014, 09:54 AM
Zmg00camaross's Avatar
Look at his build thread!!
Old 02-15-2014, 11:00 AM
Patsy57's Avatar
Who's build thread?
Old 02-15-2014, 11:01 AM
Patsy57's Avatar
Missed that lol
Anyway I will post some pics soon
Old 02-15-2014, 11:44 AM
LPE 403's Avatar
Just an ITB Paul.... .
Originally Posted by Patsy57
Missed that lol
Sooooo.....you have to use the stock breather or not
Old 02-15-2014, 04:22 PM
Patsy57's Avatar
Ok here are the pics to use this its attached to the old oil cap which fits in the stock filler neck. If you look at the threads it doesnt fit in the fabbed valve covers of course.
so my question is, is there an adapter or something to make this work?
Attached Thumbnails Billet Valve Covers Threaded oil cap and Stock Fill Tube?-img_5668.jpg   Billet Valve Covers Threaded oil cap and Stock Fill Tube?-img_5669.jpg
Old 02-15-2014, 05:34 PM
Paul Bell's Avatar
OH OK, this thing:
Old 02-15-2014, 05:47 PM
Paul Bell's Avatar
Alright, back on topic:
I don't think anybody makes a specific part to do what you want, you'll need to fab something up.
LPE above seems to think it's an AN thread. Makes sense for Moroso to use an AN bung. If so, just get a O-ring sealed AN adapter. Moroso should be able to tell you the size.
Old 02-15-2014, 07:18 PM
Patsy57's Avatar
Interesting and no check valve type connection needed to do an fitting on the valve cover and then to clean air source?
Old 02-15-2014, 07:24 PM
Paul Bell's Avatar
That would be determined by the setup you're getting from from RX Performance.
Old 02-15-2014, 07:32 PM
Patsy57's Avatar
Already got it. Since one side connects direct to the 1LE above by swapping that I would have an AN fitting in its place. The opposite end connect to air inlet tube.
So I would assume by demoing 1LE it would just be a straight line no check valve at that point.
Would that cause an issue?
Old 02-15-2014, 07:47 PM
Paul Bell's Avatar
Is this what you need to get on that threaded oil fill?
Old 02-15-2014, 08:07 PM
Patsy57's Avatar
That is what I have (shown in pics) the threading on the bottom of that doesn't go into the NpT threads in the valve cover. It's made for a standard filler neck
Old 02-15-2014, 09:29 PM
LPE 403's Avatar
OH OK, this thing:
Nope...Kinsler....first one in an fbody. One off piece to fit my Mast Inline's....gotta feed 460" on the street somehow
What's the OD of that filler neck....has an o-ring too, yes? I'm thinking if you can find a "neck" that will thread into your cover and have the right ID , you might be able push the breather into the neck. Just pray you don't have any crankcase pressure.....
Old 02-15-2014, 09:44 PM
Paul Bell's Avatar
Patsy, it looks like that 1LE breather is somehow attached to a stock style oil fill cap. As the cap always stops at the same spot when twisted in, they can affix the breather to the cap. It's indexed.
To get that breather on a threaded cap, you'll need to also get it indexed so the breather is pointed correctly with the cap all the way in.
Your next problem? The stock cap goes onto the extension. Without that, the breather on your threaded cap may hit stuff as you twist the cap onto the valve cover. You may need to space the breather away from the threaded cap.
Quick Reply: Billet Valve Covers Threaded oil cap and Stock Fill Tube?
