Nitrous retard with a 6al
Old 02-15-2014, 10:16 AM
glterren's Avatar
Default Nitrous retard with a 6al
of course i have a 6al box that i got for free out of a old corvette, im looking to spray a 200 shot and looking for the best combo to pull timing with that box. I have a 93 formula.
Old 02-15-2014, 11:04 AM
96capricemgr's Avatar
Mods to the car?
200hp worth isn't going to give you a 200hp gain unless the rest of the setup can move the air.
Looking for a window switch and spark based rev limit too?
Is the pcm tuned for more timing advance?
Old 02-15-2014, 11:32 AM
glterren's Avatar
when it all gets put back together it will have le2 heads. and cam
58 mm throttle body
nitrous outlet plate kit
headers
Old 02-15-2014, 11:33 AM
glterren's Avatar
ill have a pcm for less tune 93s have to use chips
Old 02-15-2014, 06:22 PM
Chopstix's Avatar
I would suggest upgrading from the 6al to either the digital6 or the the new programmable 6al-2. Many on here will suggest the Mallory 685 for its included window switch. But for a large shot of nitrous an external nitrous controller would be better suited and give you better results.
Old 02-15-2014, 06:38 PM
kris72079's Avatar
Doing something with the bottom end while its apart? While I hit my stock lower with 150hp all day, I believe that's the common consensus as all you want to use on a stock base.
Quick Reply: Nitrous retard with a 6al
