P-1SC tentioner pulley not lining up
I bought this from a member, the bracket is for A lt1 camaro AB011-4. The tentioner has no numbers on it at all. The crank pulley has DC009A-8 its 8 inch 8 rib. When the bracket is instslled on the charger the tentioner sits to high for the belt to work correctly. I have a manuel that Bob sent me and that was helpful but did not address this. Maybe i have the wrong tentioner or pulley just not sure what i need. The bracket fits the car perfect, the crank pulley fits the tentioner not.
Pictures attached
Pictures attached
Im starting to think i have a LS1 pulley on the blower instead of a lt1 pulley. Can someone please post a picture of there lt1 blower pulley for a procharger so i can compair the 2. Bob said lt1 use a offset pulley and i want to see one before i go ordering anything. Thanks Tom
This looks like my issue, my pulley is flat and yours stick outward. Someone must have swapped the pulley to a ls style. Thank you for taking the time to post this picture it helped a lot
Location: Weatherford Tx 76085 corner of N. Hwy 51 and 150 Green branch Rd.
Not sure if you have it all figured out, but the blower pulley is definitely not the right one. Lt1 uses an offset pulley.
