Not sure whats stock and whats not...
Proud owner of a new used 2002 Camaro SS with 90k miles.
Factory options include:
Functional hoodscoop
SLP lid
Hurst short-throw shifter
Traction control w/ dash switch
Aftermarket options (the ones I know about)
Kooks longtube headers
Offroad Y pipe
Bolt on/off cutout
Attached are pictures of the throttle body and PCM/MAF. Are these stock or aftermarket parts?
SLP lid
Offroad Y pipe
Bolt on/off cutout
Stock
ported
The area in front of the blade is made larger an lips which disrupt airflow are removed. Often the blade shaft is cut off on one side to make the total opening available slightly larger. It will improve throttle response mostly, but can flow slightly better than stock.
ported
