About to pull the trigger... What do you think?
Ready to pull the trigger on the turbos for my build. JZ over at forceinductions recommended two s300 61s with a .91 ar. Im hesitant due to the high a/r number, but he assured me that the twin scroll housing will help spool fast. What do you guys think?
Lq9, stock bottom. Brian tooley custom cam, possibly e85(not 100% sure). It will be mainly street driven, occasional track. My goal is to run 9s. Car is under 3000 lbs, true 4 link rear, 4l80e. I want good street performance.
Thanks again.
Thanks again.
Unless you have full twin scroll manifolds, then it makes no sense to use a divided housing.
Twin scroll only helps spool when the manifolds are actually working in conjunction with the turbine housing. And on a V8, true twin scroll as per a 4 cylinder is never actually possible anyway due to firing orders.
If a pair of 361's then I'd say yes certainly by 4500rpm, and more than likely by 4000rpm.
Check out the AGP Turbo kits they offer for the 2010 Camaro's. They offer a good range of turbos, one of which is a BW based S261.
61mm compressor in a smaller housing with a T3 based turbine for faster spool.
http://www.agpturbo.com/camaro-5-ss-agp-twin-turbo-kit/
It would be no bad thing to give them a call and see what they can suggest, and their units are physically much smaller than the 300's
Thanks for your input Stevie.
Im just concerned about how much lag its going to have. I dont want to spend $1400on the wrong turbos.
I see a lot of setups making well over 1000 horses with smaller A/Rs and mm housings.
With such a light car I dont see running 9's as being any problem whatsover though, with almost any twins.
