6.0L LS6 Upgrade
6.0L LS6 Upgrade
2003 6.0L LQ4 in a street rod.
I put a LS6 intake and want to use all of the original brakets. I have already cut and modified the alternator and power steering bracket to fit.
Has anyone used a 2007 or newer water pump to solve the issue of the top hose hitting the throttle body?
Thanks
Thanks
Yes it is the 03 TB.
The f-body waterpump will require spacers from what I have read?
Can you switch pulleys on the water pump from the truck to the f-body pump.
by using the spacer just seems like more spots to leak.
I went with the spacers and a Camaro water pump.
Didn't you have to relocate the idler pulley on the alternator/power steering bracket?
I see there is one down low below power steering how did you mount it there?
