strange adj. shocks, springs coils, upper shock mounts
Category: Steering & Suspension
Price: $1
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird
Location (State): NY
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6, LT1/LT4, Small Block, Big Block
LS Engine?: Fits LS Engine
These are single adjustable (10 clicks) drag shocks, I street drove them (just turn the **** to tighten, 7-8ish). And work gear at the track, been mid 1.4 60" on 275 drag radials with a t56, With not alot od power, 420whp cam only NA LS1, can go faster with more power. Coil over nuts turn smooth by hand,, no ware or damage like is common (used tourington bearing kit with anti seize, never adjusted with the weight of the car) Seals are clean and dry as new, never leaked or noticed any dust from leaking. Valving is still perfect and reacts with one click change making a difference. Selling because went to a different shock setup (cost 4x this ) Great super budget setup, I ran them with all the parts in the top pic. On my stock coils and mounts. Selling the shock/coils/ hardware setup, split up as some might not want the stock parts you already have. And there clean no winter low mileage parts off my car can be used to upgrade your high mileage parts. Listed with a price discount for buying multiple parts.
All parts are listed as shipped US 48, will ship outside US for more, make sure you state that. I will take paypal if you add the 3%, or a USpostal money order.
One pair of strange S5271 shocks, comes with the new upper coil mount to run a 2.5 OD coil. And bearing kit ($35)
http://www.summitracing.com/parts/str-s5271
SOLD
2001 LS1 camaro front coils, and coil isolator
$45 shipped (heavy, $25 with shocks)
Lower coil seats, (lower left in pic) fits on coil over adjuster on strange/QA1 maybe afco shock. And sized for a stock coil. (you need these to run stock coil springs these shocks) Similar to BMRs that sell for $70
SOLD
2001 LS1 camaro front upper strut mounts. Clean, soild not rusted out or cracked. All bolts, the thread turn buy hand with no damage. These cost 50-75$ each new, and do not come with the inner triangle spacer parts and are very hard to fine in good shape.
$75 shipped (60 with the shocks)
