73 Camaro L92 Swap
Old 02-20-2014, 01:40 PM
NemeCes's Avatar
Default 73 Camaro L92 Swap
Hey guys and gals,
Finally got my hands on a 6.2L L92 for my Camaro. The original plan was to drop an LS1/T56 in there but a friend of mine presented me with this engine at a price that I couldn't pass up.
Thus far, I have the engine and ordered adjustable engine mount adaptors from Dirty Dingo Performance. I plan to use my TH350 Transmission until I can save up for a T56. I read that I need a flex plate adaptor to make that work.
Plan is to have a very streetable 400+rwhp weekend cruiser. This isn't going to be a racecar build or anything crazy.
This is the parts list I've compiled so far:
OEM L92 motor mounts
VVT Delete Kit
1 7/8" Long Tube Headers
Aluminum Radiator W Dual Fans
LS1 (98-02 F body) Oil Pan Kit
Aftermarket Cam
Torque Converter w 3000-3500 Stall
Transmission Oil Cooler
EFI Prepped Fuel tank
255lph fuel pump
Fuel pressure regulator
Fuel lines
Cold Air Intake
Let me know if you guys have helpful info. Still debating dbw or dbc. I'll update as I get more parts in. Plan is to have this bish running in a month. We'll see how that goes.
Now on to a few pics
Old 02-20-2014, 05:05 PM
CBM Motorsports's Avatar
Love the build. Reminds me of when I did mine! PM me any questions you have about the conversion and I will help out with what I can.
Old 02-21-2014, 12:24 PM
NemeCes's Avatar
Thank you! Will definitely take you up on that offer. Going to do more research and get more parts in then I will pick at your brain.
Thanks again!
Old 02-21-2014, 02:24 PM
Sebtarta's Avatar
Running in a month? You better get cracking on ordering the stuff!
My favorite car and body style!
Old 02-22-2014, 09:53 AM
NemeCes's Avatar
Yup you're right. Getting started today.
Old 03-15-2014, 08:46 PM
NemeCes's Avatar
Got the goodies flowing in...
Derrty Dingo Adjustable Engine Mount Adaptors
New OEM Engine Mounts
VVT Delete Kit
LS2 Timing Chain
TSP LS3 Cam 231/236 111 LSA
Dynatech 1 7/8" LTs
New FI Tank w 255lph pump
Griffin Radiator w dual fans and shroud being built
Just need to figure out the electrical harness situation. Currently looking at Current Performance Wiring.
Also need to get all of the necessary pieces to get the TH350 to accept the L92.
Looking at another month at the very least. Initially deadline was too optimistic.
Old 03-15-2014, 09:04 PM
fire67bird's Avatar
Nice ride!
You are going to need to order a Dakota Digital VSS adapter so you can use the factory speedo with the TH350 unless you have already converted your gauges.
I recommend going DBC so you can do your kick down cable easily and it also eliminates another variable that can cause you heartache. Since it looks like you need harness and computer just order one with a stand alone DBC flash.
You can do the PCM programming yourself if you go ahead and just spend a little extra cash to get the HP Tuners software(multiple tunes available in HP Tuners vault). It will enable you to make adjustments as you make mods to your car or if you run into issues and wanna change something up with your build.
Old 03-16-2014, 06:19 AM
GC99TA's Avatar
The car looks great! I look forward to seeing this come together.
Old 03-16-2014, 04:44 PM
ZROCWS6's Avatar
Going to be fun following this one!
Old 03-16-2014, 06:52 PM
M6 Swap's Avatar
cool build, subscribed
Old 03-16-2014, 11:59 PM
NemeCes's Avatar
Originally Posted by fire67bird
Nice ride!
Thanks for the heads up about the vss adaptor.
This is what I'm still figuring out. Was actually thinking of going dbw but I have yet to make my mind up.
I'm actually just going to get it dyno tuned at a buddy's shop. Engine is going to stay as is for a while as I'll be focusing on suspension and a T56 after she's up and running. She'll be pretty mean with intake, cam, LT's, and 3" exhaust.
Thanks. I can't wait til she's up and running.
Sounds good man. Will keep you guys updated.
Thanks!
Old 04-09-2014, 08:32 PM
NemeCes's Avatar
Just ordered the adaptor to run my th350 along with a 3200rpm stall torque converter. Also ordered some boring stuff like valve cover gaskets, head gaskets and head bolts. Ride is going under the knife in two weeks after I get these parts in.
Anyone know where I can get a cold air intake for this bad girl?
Old 04-16-2014, 11:41 PM
NemeCes's Avatar
It's getting real
Engine and parts on their way to the shop.
New Cam Installed
Heads reinstalled
Ready to go!
Getting the ride to the shop for the engine swap in the next few days.
Old 04-17-2014, 08:37 PM
Adam123's Avatar
I live that color silver, beautiful car. Have fun with your swap.
Old 04-17-2014, 08:58 PM
NemeCes's Avatar
Thanks! I definitely will.
Old 04-18-2014, 09:13 PM
slogo's Avatar
Man I'm so jealous, those 2nd gen Camaros are my favorite, I can only imagine how fun
it will be with the new power. Good luck and enjoy
Old 04-24-2014, 10:34 PM
NemeCes's Avatar
Thanks man. For now, me too. Soon, hopefully, I won't have to imagine how fun it'll be because she'll be ready!
Old 04-24-2014, 10:41 PM
NemeCes's Avatar
Sitting pretty! Waiting on the harness ordered from Sean at CBM, fuel rails and MSD wires.
Closer engine bay shot.
The huge intake mani might have barely cleared a stock hood. Shouldn't be a problem since I have a cowl hood.
Closer pic to how the engine sits with the dingo adaptors. I originally thought that I had to use the stock L92 mounts but it actually uses the stock Camaro mounts.
Pretty excited that she's coming along nicely. Gotta figure out a snag with my radiator and should be good to go after the harness is in and the tranny and fuel lines are run.
Old 05-22-2014, 12:10 PM
NemeCes's Avatar
So we got the car to turn on last night. She's almost done and driveable. As soon as she's all set up, I'm going to send her to the next shop to get a posi unit out back with some 3.73's.
Once that is done, off to get tuned
Will get some pics up later.
Old 05-22-2014, 07:30 PM
sako's Avatar
Looking Good.
Quick Reply: 73 Camaro L92 Swap
