how do I hide AIR HOSE, drivers shock tower...
I want to clean up the engine bay a bit more...I have already hid the PCM wires, now I want to hide that nasty air hose on the drivers shid shock tower brace...I am also deleting EGR/AIR...how do I hide that thing? I do have the small k/n air filter thing at the end of the hose by the front headlight...will i have to hide this as well? cuz it looks kinda cool
i juss want to hide the most visible part on the shock tower...i have removed all stickers...have some cuztom candy apple red parts going in...its comming along nicely...have no pics tho...ne wayz, how the hell do i do this...i checked out Xsta Z28's web shots, but I need some more words to go with the pics on how to do this...
I know Xsta Z28 has done this...has anyone else...if so, please give step-by-step instructions...
engine bay clutter...
parbreak: are you positive? I believe steve deleted his EGR/AIR, and he still had a red hose there...hmmm...well, if ur right...what happens to the k/n air breather on the end of my hose? or is that hose seperate?
sorry, confused...
btw...I got a set of FRC's from you...they were beautiful...also adding some dark candy red ghost flames to them...i'll send u pics once done...
sorry, confused...
Yea, I just threw away the breather filter. Not needed if you delete the AIR system and the hose. Oh, by the way, you will need to have the codes deleted with LS1Edit if you pull the pump also.
And, thanks for the compliments on the FRCs!!
Bryan
parbreak
Bryan
parbreak
guys: thanks for the info...good thing I won't need the k/n breather...but seriously, i thought it looked kinda cool for some reason, had it set up where it looks really clean...not just "thrown" on there...my girlfriend said its "cute" LOL ne wayz...good thing that piece of **** can be totally removed...
oh and as for the codes...speedinc. in shaumburg is taking care of that for me so i can pass emissions...
emissions
emissions
Moderator
Or if you still have AIR, you could follow the hose,
pull it out, cut it off where the end will be up over
the engine and put the breather / filter back on
and retuck it out of sight.
ur still gonna have the hood release line running down that side, unless u drill a nearby existing hole larger and re-route it much the same as the !wire mod. i did it and it was a piece of cake, no wires or anything on either side for me.
Originally Posted by Cody Brooks
i tucked mine under the fuses and then ran in under the master cylinder against the fender so that you can't see it unless your say looking at the steering shaft.
Thanks
Bryan
