Fresh off engine rebuild, oil pressure issue?
So I recently had a engine rebuild (prob @ 2500 miles on the build now), complete with new cam, LS6 oil pump and all that. Since getting the car back, oil pressure was consistently in the 60-80 psi range, on occasion after warming up it would stay in the 50-60 range. Recently over the past day or two I've noticed the car running at a lower psi. 40 ish psi (which I know is fine), but today it dropped down low enough to set the check gauges light on. Since the rebuild, I've had everything checked by the shop that did the build, everything was good, oil changed etc. Car still has plenty of oil, no issues there, so any ideas of what may be going on? Spent decent coin on the rebuild and this is making me a tad nervous esp since the car has been doing fine since I got it back. Any feedback is appreciated!!
o-ring
Possibly the o-ring on the pickup tube/or mounting bolt loose, but the dropping oil pressure over days is not a good sign. Is the gauge working normally or possibly the sensor is going bad.
Thanks for the response!
