fixed idle and now hangs up
Old 05-12-2004, 03:28 PM
taqwache's Avatar
Default fixed idle and now hangs up
i just got my car to idle fine with the ac on and ps working. my ICA counts wtihout AC are 30+- and with AC on they are at 120+-. this seems to be fine but when i put the car in nuetral and rev it up, it gets hanged up at 2K for a long time before the IAC counts come back down to where they are suppost to. how can i get rid of this delay. keep in mind that i have a TH400 on a M6 program and no speedo. does anyone have an answer?
Old 05-13-2004, 09:01 AM
taqwache's Avatar
TTT anyone?
Old 05-13-2004, 09:50 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
How big of a hole do you have in the TB blade Steve?
Old 05-13-2004, 01:10 PM
taqwache's Avatar
in order to get it to idle, i had to go 9/32 and then a second 3/16 hole. that was the only way i could get the idle at 1000 and get the IAC counts at 34 AC off. it idles perfect and does not dye any more but it just hangs up every now and then, what do you think?
Old 05-20-2004, 07:45 PM
taqwache's Avatar
nobody?
Old 05-20-2004, 07:46 PM
taqwache's Avatar
today i tried completly disconnecting the IAC and it still does it.
Old 05-21-2004, 01:27 PM
TIMMEH's Avatar
You drilled 2 holes? When you say it hangs up...like the RPMs don't come down...ie cruise control effect?
Old 05-21-2004, 01:32 PM
HumpinSS's Avatar
http://www.ls1tuning.com/iboard/index.php?showtopic=9
