I have a 1993 trans am. Weird year but what's a good scan tool?
Old 02-23-2014, 09:38 AM
ShovelMan's Avatar
Default I have a 1993 trans am. Weird year but what's a good scan tool?
I can't find anything online, only people recommending software. I need the cable that connects my laptop to my car.
Thank you
Old 02-23-2014, 11:12 AM
DirtyBirdMKE's Avatar
i think you need to get some kind of jumper crap and a different reflashable chip... something like that.... i rad about it awhile ago when i was going to buy a 93
i think you can get it through TunerCATS
Old 02-23-2014, 07:04 PM
lt1-xjs's Avatar
Moates.net has every you need for tuning hardware. To scan for codes all you need is a paper clip.
Old 02-23-2014, 07:09 PM
metalmilitia606's Avatar
93's are old enough you can jump the pins like others have said.
Old 02-23-2014, 10:25 PM
ChevyOwner's Avatar
You can buy all the needed tuning supplies from moates.net as has been said.
In addition to that if you buy ALDU1_CABL1 you can use TTS datamaster for data logging and reading/clearing DTCs
Old 02-23-2014, 11:34 PM
Moderator
BizZzatch350's Avatar
TTS Datamasters is what I used when I had the stock ECM along with a Moates cable. Worked pretty well.
Old 02-24-2014, 09:53 AM
smitty2919's Avatar
I downloaded DataMaster and ordered a cable from TunerCATS for my 95 to go from a OBDII port to USB.
Cable should be arriving today actually.
Old 02-24-2014, 05:56 PM
nomoneyz's Avatar
Your 95 is OBD1 not 2. Hope you ordered the correct cable. It has an OBD2 style port but your ecu is still OBD1. Unless ofcourse you swapped to OBD2. Then forget anything I said.
Old 02-24-2014, 08:52 PM
cardo0's Avatar
I picked up an older Auto Xray for $40 at a swapmeet. It works to read DTC codes and does real time scanning also. Nothing fancy but havent found reason to buy newer/better yet. But u do need the GM cable/connector.
U might find them on ebay.
Good luck,
cardo
Quick Reply: I have a 1993 trans am. Weird year but what's a good scan tool?
