cutlass 6.0 swap th400 to LS
Hey guys i have a 99 6.0 i got out of a 99 silverado 2500 and its going into my 87 cutlass. So far i have the carb/intake, headers, oilpan kit, and swap plates. the trans I'm using is a th400 with a converter. I've been seeing different reviews on what to use to mate the engine to the trans . also what msd box are you guys using.
Thanks
Thanks
I use a MSD 6010 box and it's worked good so far. Don't quote me but I'm pretty sure with a 99 motor you don't have to add a spacer. Mine was an 02 and I had to add the spacer in between the flex plate and converter because my flex plate is dished.
