2004 LQ9 Harness to 1996 V6 Camaro
I'm swapping my LQ9 into my 96 v6 camaro. I'm trying to figure out which wires of the C152 and C100 plugs go to where the C210, C220, and C230 plugs on the v6 harness so that I can make it plug up under the dash by the passenger side kick panel.
Also, my lq9 harness has an AWD plug and no C153
I will be using an LS1 0411 PCM with this harness so I know I will be doing some repinning later but for right now I just want to get the V6 plugs onto the LQ9 harness. I just can't seem to find a good diagram to show which wire is which for either harness.
LS1Tech Sponsor
I don't know what kind of budget you are working on but we build a plug and play harness for your application. Factory replacement quality for your swap, right down to the new fbody specific firewall grommet.
There are a ton of threads on here about the same swap and the success rate varies. Just something to keep in mind.
Alldata is a good source for all the diagrams you need.
Bill
Bill
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
1-888-467-4491
