Quick spool turbo for 700 fwhp 5.3 on E85
Old 02-23-2014, 05:51 PM
fieroguru's Avatar
Default Quick spool turbo for 700 fwhp 5.3 on E85
I am about a year away from adding a turbo to my LS4/F40 powered Fiero. It is daily driven in the summer and I want to build it for the street as it only sees the track 1 weekend per year (LS Fest).
Engine is 2007 LS4 (aluminum 5.3 w/ 799 heads, 10:1 compression) and the long block is stock with the exception of the camshaft (will be changed when I add the turbo - LS9 or custom turbo cam for the combo) and I don't plan on any upgrades to the rotating assembly. The engine only has 27K miles on it.
700 fwhp will be more than enough since the transverse manual transmission has about 15% driveline loss and the car will see 600+ whp and weigh 2950 lbs. Any more and it will just break more parts.
I would like to keep the LS7 exhaust manifolds (factory heat shields help keep the engine bay temps down) and just taper the collectors to a 2 or 2 1/4" crossover.
I would prefer a single turbo vs. twins for simplicity and space considerations.
Since this is a street car, I would like to see boost start building in the 2000 to 2500 range and have it peak in the 3500-4000 range and max rpm being 6500-6800. I can read the compressor maps to find the right compressor size, but my concern is on the exhaust side. I want something that spools quick but doesn't become a restriction until north of 750 hp.
Any suggestions on turbine size and A/R ratios would be very helpful as there isn't much info on the exhaust side. Most dyno graphs with the 5.3 don't start till 3-4K rpm so its hard to see how early it starts building boost.
Old 02-23-2014, 05:57 PM
ZGLASS's Avatar
here mine pt 7175 billet. .81 ar. this was 20lbs
Old 02-23-2014, 07:17 PM
LS1NOVA's Avatar
Turbonetics 7575.
Old 02-24-2014, 06:18 AM
w94rx7tt's Avatar
I run a precision 6766 1.32 ar . Spin to 6250 and made a little over 650 @ 15lbs.
Old 02-24-2014, 09:38 AM
Forcefed86's Avatar
Depends on the budget. The small wheel S475 1.10 T4 setup would be your best bet price/performance wise the quickest spool. Should make your power goals as well. Jump to the billet fancy wheels if budget allows.
Old 02-24-2014, 09:46 AM
Photochop's Avatar
TC76 is cheaper and probably work just as well for your goals
Old 02-24-2014, 01:48 PM
geoff17's Avatar
I agree and I have a BB one for sale for the right price with the 3.5 inch down pipe discharge instead of 3 inch. PM me if interested. Mine has brought me to a 9.86@140 on only 15psi on a 6.0L and full exhaust and spools dang near instantly.
Old 02-24-2014, 07:04 PM
fieroguru's Avatar
Thanks for the suggestions so far! Please keep them coming.
I like the spool on this one, the power level is too high, but I could likely just run less boost.
Is this with a 5.3L and if so do you have a dyno chart?
Old 02-24-2014, 07:29 PM
ZGLASS's Avatar
16 lbs in this graph. same power curve at 12 lbs just 630/630 this is a rear mount c5z six speed.
Old 02-25-2014, 06:25 AM
w94rx7tt's Avatar
Yes it is with a 5.3.
Old 02-25-2014, 06:36 AM
Forcefed86's Avatar
Thats a pretty torque curve! What cam is used on that?
Old 02-25-2014, 07:21 PM
w94rx7tt's Avatar
Thanks. I contacted Baker Engineering and they hooked me up with it. They are great and easy to work with. This 67mm probably has another 100 wheel in it before it's done .
Old 02-25-2014, 09:29 PM
fieroguru's Avatar
That is quite nice! I will have to take a very close look at this one!
Thanks!
Quick Reply: Quick spool turbo for 700 fwhp 5.3 on E85
