4l60e to 5.3 question
Old 02-24-2014, 01:30 PM
gpr
gpr's Avatar
Default 4l60e to 5.3 question
I have a 4l60e, tranny and flex plate out of a 2002 camaro. I want to install and run it with a 2004 5.3 truck engine. Will the converter bolt directly to the truck flex plate with nothing else needed?
I installed a 4l80e into the 2002 camaro, and when i did that i had to use a 6.0 truck engine flex plate for it to be spaced properly. wondering if i need a spacer for the 5.3 and 4l60?
Old 02-24-2014, 05:11 PM
ls1nova71's Avatar
As long as you have the 4l60e flexplate the 4l60e will bolt to your 5.3 with no problems .
Quick Reply: 4l60e to 5.3 question
