Anyone running napa clutch with muncie
Old 02-24-2014, 06:59 PM
kodyowenby10's Avatar
Default Anyone running napa clutch with muncie
looking at this clutch http://www.napaonline.com/Catalog/Ca...064_0315031525 with a sachs 1050 flywheel for my 55 chevy with a 5.3 and a muncie anybody else used it or maybe the http://www.napaonline.com/Catalog/Ca...105_0417779030
Old 02-25-2014, 11:26 AM
speer13's Avatar
I think its really going to depend on a few things....power/torque the engine will be making, weight of the car etc. I have seen NAPA clutches live a long time in a stock vehicle and I have also seen them fall apart on a 300 rwh car...driving style also has a lot to do with it lasting.... for the extra 80 bucks I'd get a Ram clutch or something made to handle a few hundred horse to be safe....
Old 02-25-2014, 12:33 PM
garys 68's Avatar
What's the application for the clutch? SBC and BBC car are smaller than the truck clutches. I know the 1050 is drilled for the car clutches, not sure if truck is different.
Old 02-26-2014, 10:20 PM
I thank a 76ish 3/4 ton the disk hits more area of the flywheel than any of the others I tried around 1/4inch hanging off. It does have the same bolt pattern as the cars.
Old 02-27-2014, 07:23 AM
garys 68's Avatar
You may need the truck bellhousing too. Larger pressure plate might not fit the 621.
If you go with the truck bell, it has a larger cutout for the Muncie car trans bearing retainer. You'll need an adapter.
Quick Reply: Anyone running napa clutch with muncie
