dual or single 044 LS1
Old 02-24-2014, 10:06 PM
94 s dime's Avatar
Default dual or single 044 LS1
im building a drag car currently, sbe ls1 heads, cam, supervic w/ puck. question i have is one 044 enough to support this power level? i have 2 but if its going to be overkill on a h/c/i ls1 with nitrous i can just run one. the current setup as it seems will be fuel cell, two 8an feeds to pumps, 8an y to a single 8 to the rail. than a 6 return. thanks!
Old 02-27-2014, 08:33 AM
2muchboostNY's Avatar
Not sure if this helps any but if you are running E85 or a derivative of it the twin pump setup has seen well over 800rwhp. My buddy on a 2JZ on E81 hit 766rwhp and 648tq with lots more in the fuel system but he was on a stock block so decided to cap it off there. I had read somewhere that on pump gas the twin 044 setup is estimated to be good in the high 900rwhp range but its going off my terrible memory.
Quick Reply: dual or single 044 LS1
