Can anyone tell me what happened here?
Old 02-25-2014, 09:32 AM
djloc79's Avatar
Default Can anyone tell me what happened here?
https://www.dropbox.com/s/u9ico7oot0...220_132330.mp4
Ur thoughts?
Attached Thumbnails Can anyone tell me what happened here?-forumrunner_20140225_093137.png   Can anyone tell me what happened here?-forumrunner_20140225_093150.png
Old 02-25-2014, 09:43 AM
usdmholden's Avatar
Looks to me like the driveshaft broke.
Old 02-25-2014, 09:45 AM
ls1nova71's Avatar
Not exactly sure what happened, but it looks like you exceded the horse power limit of your driveshaft.
Old 02-25-2014, 09:48 AM
hackster's Avatar
^^^ What he said....I bet the guy running the dyno had more to say about it though =)
Sean
Old 02-25-2014, 10:58 AM
Project GatTagO's Avatar
Received 1,391 Likes on 879 Posts
Looks like a classic case of the driveshaft turning into a jump rope. This happens as a result of the driveshaft exceeding it's critical speed. Did this happen on a chassis dyne?
https://www.markwilliams.com/driveshafttech.aspx
Andrew
Old 02-25-2014, 11:01 AM
wavebyby's Avatar
^^^ hahaha.....time for a new drive shaft , weird how 345 hp bent it like that but i dont know **** lol
Old 02-25-2014, 11:05 AM
Power had nothing to do with it.
Andrew
Old 02-25-2014, 11:17 AM
sweetk30's Avatar
stupid drive shaft . . . . your made to spin round and round . . . NOT make turns
Old 02-25-2014, 11:27 AM
ROCNDAV's Avatar
When VW was playing commercials talking about torque, my (non car) buddy asked me what torque was and if a car could have too much torque.
That would be a good picture to show him
Old 02-25-2014, 11:32 AM
thunderstruck507's Avatar
as mentioned above look up critical speed
HP has nothing to do with it; it's the result of material weight, driveshaft length, diameter, and RPM
Old 02-25-2014, 11:33 AM
bczee's Avatar
Either you exceeded the power limit or ( most likely) it was either damaged or a badly made tube. Was this a new or used shaft? Was there any dents, bumps or fold/seams in the tube?
BC
Old 02-25-2014, 12:04 PM
djloc79's Avatar
Sean
Yeah, he mentioned that maybe the trans sized up or the pinion angle was off.
Andrew
Not sure what u mean. Chassis dyno?
Old 02-25-2014, 12:07 PM
djloc79's Avatar
BC
It was a used driveshaft. If there were any dents, or folds, they were to small to notice.
Old 02-25-2014, 12:12 PM
djloc79's Avatar
I failed to mention, It ripped the tail housing off the trans. My mechanic thinks the driveshaft could've been a little to long. Also, I came across this right up-
http://www.turbobuick.com/forums/thr...y-pics.179024/
Mine was running 138 mph when it broke.
Old 02-25-2014, 01:13 PM
Won't hurt to check driveline and pinion angles and all that, but I highly suggest you google "driveshaft critical speed" and do some reading before buying a new driveshaft.
I had this happen and it took out a brand new built 4l60e with it. It busted the case and all.
Every short wide truck I have ever seen try to turn to redline on the dyno has also done the same thing.
Old 02-25-2014, 01:49 PM
Chicago TDP's Avatar
138MPH....holy shyt!
Old 02-25-2014, 08:22 PM
Pop N Wood's Avatar
It is an oversimplification to say "power has nothing to do with it". Just because something hit a resonant frequency doesn't mean it is going to blow up. Think guitar string. Hitting a resonant frequency does amplify the forces going through it making less capable of carrying all that energy, especially if other flaws or weak points are present.
At any rate pretty fing cool. Must have been something to see.
Old 02-25-2014, 09:17 PM
1970camaroRS's Avatar
You can twist a driveshaft with 100hp if you spin it too fast. Like others have said, it's a critical speed issue, not power. Probably bad pinion angles too (did you lower the car?) because that can make it worse. Could also be too long as that would make things worse as well. But you're just spinning a stock shaft at too many RPMs, just that simple.
Old 02-26-2014, 06:16 AM
Old Geezer's Avatar
What Andrew said^^^^
Used shaft. Any evidence of rust, either on, or inside?
Talked w/ the shop I get my d/s from. They said that near 90% of the F body shafts they spin up, looking for vibration issues, show signs of deflection in the exact same location... The middle.
http://www.wallaceracing.com/driveshaftspeed.htm
Old 02-26-2014, 07:51 AM
djloc79's Avatar
Ok I'm kinda getting and understanding of critical speed and and what happens when this point is reached. What I'm not getting is a drive shafts critical speed something that stays the same the life of the shaft as long as the length, width, material type...etc, is not altered, Or can an unaltered drive shaft's critical speed rating decrease overtime as it is worn. I've seen old cars with old driveshaft go fast with no problems. It almost sounds like a new drive shaft is a must when hot rodding a older used vehicle.
Quick Reply: Can anyone tell me what happened here?
