need dry kit info... fbody ls1
im new to the fbody world and have some questions?????
im looking at a dry kit for my car..these r the mods i have for my car
full true dual exhaust, walbro 255 pump
asp crank underdrive pulley asp alternoty pulley
slp ported oil pump
lunati dual roller timing chain
lunati 232/238 113 cam
92 fast intake and 92 throttle body
spec 2+ clutch
410 gears
`1. which kit would be best for the set up i have money is not an issue better be safe than sorry??
2 what shot should i use with my set up that i already have and will stock injectors still be fine?
3 i want i kit i can hide was looking at the hidden halo kit and info on that kit
thats all i can think of as now but if someone could help me on this would be great
slp ported oil pump
spec 2+ clutch
410 gears
I'm thinking 50-100 shot but whatever would be safe if I have to upgrade injectors that won't be a problem either just trying to get all cards on table before I start shopping. buy all at once I. hate waiting for one simple thing
Well the way I would look at it is anything less than a 100 shot is a waste of time IMO, so with that in mind you probably will need to upgrade the injectors with a dry kit
The only dry kit I ever used was on my Mustang and it was just a basic NOS kit. Not really sure what the LS guys are usuing in the way of dry kits these days, but I have a few friends who have had great success with the NOS dry kits as well
I don't mind if it was visible but after I did research I saw lot of people wants to hide it.. Saw on pic where he ran it under the entire air box and used a 90 up under the lid also had the solenoids under too but I believe I'm sold on the halo unless somthing else comes up but I wanna run a 100shot will stock injectors hold up or do I need to upgrade
i just bought the car how it sits and i was curious about that also guy said it was ok but im putting 42# in it i dont like being close to the max on injectors.. i like having plenty of room for fuel..
im new to the fbodys but the reason he likes them cause it comes with all the proper certs for each injector shows all the pounds it was tested o... flow and ect ect other than others all it comes with is the receipt..lol
