sbc to LS reloaction brackets
Does anyone have a print with dimensions for an LS motor mount bracket? I am running a TCI front clip on my Chevy II and it comes with pedestals for an sbc. I'd like to use our waterjet at work to make a pair of these plates. Thanks.
Rob
Rob
I'm a toolmaker by trade...........it'll take me 5 minutes to imput print into computer and 5 minutes later my 3/8 stainless brackets will be done.................and I'll get paid for it!
Are you wanting the motor to sit in the exact same place as the SBC did? Sharing that bottom hole does not locate the motor in the same spot to bolt to trans. If your changing motor and trans then it really won't matter since you usually have to do something with the transmission mount anyway.
