need direction on fuel system
Old 03-01-2014, 01:26 PM
erskine's Avatar
Default need direction on fuel system
i got a 600hp engine and gonna run 80lbs injectors with E85. i just need help with the rest of the system or what to do.
Old 03-01-2014, 03:03 PM
maroonls1z's Avatar
Need more info on vehicle
Old 03-01-2014, 04:40 PM
erskine's Avatar
13 to 1, solid roller cam, 243 ported heads, 408ci
Old 03-01-2014, 05:29 PM
LS1Tech Sponsor
COSPEED2's Avatar
He means entire setup please. Give us all the info you can and we can fix you up with the appropriate fuel system.
On a side note, why do you say that 408 makes 600? Is that dyno proven or engine builder idea?
Old 03-01-2014, 05:34 PM
erskine's Avatar
gone?
Old 03-01-2014, 05:37 PM
LS1Tech Sponsor
COSPEED2's Avatar
Well that answers that. We can sure get you set up. To keep better track of the conversation, please email us at the link in my sig and we can get you taken care of from fuel pump to fuel rails to injectors and everything in between.
Old 03-02-2014, 12:38 PM
maroonls1z's Avatar
Well your gonna need ptfe lines, they say E85 requires about 30% more fuel so ull need a set up that con support AT LEAST 1000hp pump gas. 1/2 inch or -8an feed. And pumps made for e85 to start
Old 03-02-2014, 04:57 PM
LS1Tech Sponsor
COSPEED2's Avatar
He has an email with all that info.
The worst thing about E85 is, it makes you spend ALOT more money. And sometimes they smell like a bakery/brewery from the rear.
Quick Reply: need direction on fuel system
