1999 Tahoe 2wd Drive 4l60e into camaro
Old 03-02-2014, 01:26 PM
mvrotc's Avatar
Default 1999 Tahoe 2wd Drive 4l60e into camaro
Hey quick question i have a 5.3l LM7 In my 99 camaro right now and found a police package tahoe with 2wd trans that i wanna put in the tahoe has a 5.3 in it now. Will the trans work with my motor, i know i might have to swap tail shaft
thats the pic of input shaft, it does have a bolt hole in bellhousing at 12 oclock position
Old 03-02-2014, 06:47 PM
01ssreda4's Avatar
Wont have to swap tails if you use a torque arm relo crossmember. Its a 6 bolt tail trans right? Should swap right in.
Quick Reply: 1999 Tahoe 2wd Drive 4l60e into camaro
