Need IAC plug confirmation for a 96 V6 Camaro
Old 03-02-2014, 02:49 PM
bldgengineer's Avatar
Default Need IAC plug confirmation for a 96 V6 Camaro
The IAC was missing from my camaro when I bought it. I'm currently converting a LQ9 harness to DBC and I'm trying to find the IAC plug from my V6 harness. for some reason I can only find 3 wire plugs when the schematics are showing a 4 wire plug???
Can anyone confirm this for me? The plug should have these wire colors
blue/white
blue/black
green/black
green/white
Old 03-02-2014, 03:52 PM
IDriveChevy's Avatar
It should be on the same harness string as the MAF and IAT sensor. This is the best picture I could find. The IAC is on the top left behind the MAF.
Old 03-02-2014, 04:18 PM
Thanks a lot. After some serious digging I found it. Apparently, after 18 years the blue wires must turn green when exposed because I found a 4 pin connector with 4 green wires, stripped it back about 4 feet and all of the sudden 2 of the green wires turned blue
At least your pic showed what kind of 4 pin plug to look for
Quick Reply: Need IAC plug confirmation for a 96 V6 Camaro
