Fuel system questions
Doing a 5.3 turbo build, have a stock tank with -10 feed and -8 return fitting, bought a -6 feed and return regulator, stock rails with -6 inlet. What are my options for in tank pumps and reducing the an fittings? Figure 650rwhp max. I'd prefer to run one pump
Should I use this regulator instead and use a 8 to 10 adapter on feed, 8 to 6 adapter on outler and 6 to 8 adapter on return?
There isn't much point in running large lines if you are going to chock it down at the rails. If you are making enough HP to require the larger lines then you need rails & regulator that match.
Good luck.
Good luck.
I'd say u can keep the regular and ditch the rails and get some aftermarket ones. Then u can go ahead and use ur adapter fitting in the regulator if I place it in the system behind the rails
