stock 6.0 block, LS3 heads, 408ci, F1x, 23psi=1140 rwhp on pump E85
Just thought Id share some results from a friends car. Engine is a stock 6.0 iron block stroked to 408 ci. Stock LS3 heads with work. Stock LS3 intake manifold. LJMS hydraulic roller camshaft. 1 7/8's headers and 3 inch exhaust. Oh and an F1x makin 23 psi.
Pretty killer results... and an awesome torque curve thats above 800 for 2200 rpm.
Killer numbers!
4" piping and 4" intercooler?
Velocity stack on the blower or 5" pipe/filter?
Pump gas/meth?
I assume the cam is pretty moderately sized..
I've got a 402 with an F1R at 23 psi and I don't make anywhere near that kind of power.... I've considered switching to an F1X but don't want to push more then 23 psi on pump gas so I figured I wouldn't gain much power at the same boost level I'm at with the F1R..
Pump gas/meth?
Killer numbers!
Pump gas/meth?
Pump gas/meth?
Cam is moderate in my opinion.... others might dissagree... Did the cam for a 2 or 2 1/8 primary header really.... once the new pipes go on... it should make more power.
Help!!!!!!!!!!!!
I Have A Question........
Im About To Purchase A 2001 z28 With A Lq9 In It
I Plan On Buying A 421 Stroker Kit And other Parts From Texas Speed
I Plan On Buying The Lq9 Race Heads With Magic Stick 4 Cam
And Ls3 Fast 102 mm Intake Mainfold
My Question Is.....
Will that Cam Fit
And Will It Work ???
Feed Me In On Any Info Thanks
My Question Is.....
Will that Cam Fit
Amazing results just nasty Congrats to the owner and great work from everyone involved I read the crazy owner is spraying it too!!!!
Every F1X results I've seen showing the power keeps pulling at higher RPMs more than the F2 but loosing a little bit mid range power is that right??
LilJohn I'm gonna contact you soon for a cam order for my new setup
You can start a new thread with all your questions in the right section.
My Question Is.....
Will that Cam Fit
My Question Is.....
Will that Cam Fit
Heres an idle clip. Hope the link works.
Yea.. hes spraying it and Im not too thrilled about it...lol. things having a hard enough time exhaling throu a set of 1 7/8's headers. Once he gets the 2 1/8 primaries on it id like to see on the car... itll work better.
8 Second Truck Club
Maybe I'm missing something but a maxed out f1x being sprayed that only makes 1100 rwhp seems a little low.....am I missing something????
