New harmonic balancer?
Old 03-03-2014, 04:00 PM
mhslax6's Avatar
Default New harmonic balancer?
My balancer has some rubber bulging in a couple of areas. Is it time to change it or can I still run it for a while? If I need to replace, how do I align the new one? I marked the old one with a paint marker so I could reinstall in the same place.
Old 03-03-2014, 06:29 PM
ahritchie's Avatar
Yes, you need to replace it before it comes apart and bangs around in you engine bay then flies off down the road...there's an arrow on the stock balancer, you just line that up with the triangular hump thing on the stock hub, it's foolproof. Consider an aftermarket one if you ever plan on putting a big cam and heads on it for 6500+rpm use.
Old 03-03-2014, 07:47 PM
mhslax6's Avatar
No, I will won't be adding anymore mods anytime soon. Thanks for the advice!
DUDCOUPE's Avatar
Im running a jegs balancer and an impala snout because i spaced my accessory bracket out.
Old 03-03-2014, 08:54 PM
mhslax6's Avatar
As I am on a limited budget and have had so much cost already, is there a recommendation for a good lower cost harmonic without having to pull the hub? I see Dorman and ATP have stock replacements. Anyone have experience with these brands?
Old 03-03-2014, 09:59 PM
DUDCOUPE's Avatar
Mines has 3 bolts that hold the balancer to the hub
Old 03-03-2014, 10:50 PM
BALLSS's Avatar
you can just buy the balancer part and bolt it to your hub. Doorman would be your basic replacement balancer sold at most auto part stores
Old 03-04-2014, 11:54 AM
mhslax6's Avatar
There are 3 "stock" replacement units that I can get locally. Pioneer, Dorman and Powerbond. Any one better than the other?
Old 03-05-2014, 04:00 PM
leadfoot4's Avatar
I'd go with the Powerbond.
Old 03-05-2014, 04:23 PM
ahritchie's Avatar
Agreed, they also make high quality aftermarket SFI certified ones like the one JEGS sells under their name. I have one on my car.
Quick Reply: New harmonic balancer?
