F/S-F/T Camaro SS Must See!!!!!
Year: 2001
Make: Chevrolet
Model: Camaro
Price: $7
Mileage: 59000
Private or Dealer Listing: Private Listing
Location (State): IL
Color: Black
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
Fresh LS Motor!!!!
Only Dyno time and a little Street Time!!!
Will give motor specs to (serious buyers ONLY!!)
-Custom Chevy Valve Covers
-Custom Speed Inc Cold Air Intake Kit w Lower Bottom
-Ignition Coil Relocation Kit
-MSD Wires
-All ARP Bolts And Studs
-SLP Balancer
-Edelbrock Victor Jr Intake
-Edelbrock 4150 throttle body 1050cfm
Complete Return Style Fuel System
-42lb green tops (Flow good)
-Custom Pp fuel rails #6
-Casper voltage booster Hot wire kit
-Walbro 255 In-Tank pumps
-Autometer Fuel Pressure Gauge under Hood
Driveline
-Fresh Built TH400 w/RMVB & Pro Trans brake
-ATI 5500rpm converter
-CSR Carbon Fiber Trans Shield
-Tci conversion sfi flywheel
-MSD Starter
-B&M Large trans cooler with -6an braided line
-Moser narrowed 9in factory case 4:10 Gear w/31 spline spool
-Moser axles ARP Wheel Studs
-Custom HD driveshaft with 1350 u-joints
Suspension/Chassis
-Spohn Extreme Anti Roll Bar
-Spohn Adj Rear Control arms
-Spohn adj tq arm w/ loop and good hyme
-Spohn panhard
-Spohn relocation brackets
-Moser pinion support
-Custom Sub Frame connecters
-UMI tubular TH400 crossmember
-Stock Rack and power steering
-UMI Racing Tubalur K member
-Strange Rear adjustable shocks
-Stock Front upper and lower control arms GM ball joints
-Qa1 front adjustable coil overs
-Custom Front travel limters
Brakes/Wheels & Tires
-PowerStop rotors in all 4 corners w/Hawk pads
-Bogart d-10 wheels 10s rear 3.5 front
-ARP studs all around
-SLP Line Loc
-Mickey Thompson Front Tires BRAND NEW
-Mickey Thompson Rear
Custom Full 4" Exhaust
-Kooks Coated 1 7/8" to 2" longtube headers
-Custom y-pipe into stainless 4in Magnaflow muffler all the way Back!
Exterior/Interior
Body has 60,000 miles, no dings, no dents, a couple small imperfections
-Entire car was Buffed
-Front SS Grill
-All Custom Lights,Front & Rear Lights
-Engine bay Painted PPG GM Black
-Fiberglass Glasstec Hood
-Original interior with Kirkey Racing Seats w Madman seat brackets
-Stock Rear Black Leather Seats
-New Custom Carpet
-Stroud race camloc seatbelts
-Stroud Chute
-Cheetah Shifter integrated into factory console
-Raptor shift light
-Lingenfelter 2 step
-AEM WideBand gauge mounted on A-pillar
-JL Door Speakers
-Tinted Glass
-Factory ECU Speed Inc tune!!!
-Yellow top Bat. Relocated to rear, On/Off Switch at rear
-Factory working interior everything works!
-Everything on the car was custom done to be different!!!!!
TOO MUCH TOO LIST!!!!!! I am sure I am missing more stuff Cash is king but Trades Are Welcome Up Or Down Let me know what you have all I can say is no Thank You
