What oil pan for turbo motor?
Old 03-04-2014, 10:36 PM
a.white86's Avatar
Default What oil pan for turbo motor?
I'm lacking an oil pan, and not sure what to get. I'll be running Huron Speed t6 kit, their PA racing turbo k member. Someone recommended I find a vette oil pan, c5 batwing one. Any ideas? Automagic, big turbo, built motor btw.
Old 03-04-2014, 10:44 PM
HexenLord's Avatar
Why not just run a stock pan? Get whatever was made for your vehicle.
Old 03-05-2014, 06:37 AM
LS1Tech Sponsor
Slowhawk's Avatar
If it's an f-body. Stock pan with baffle. That's what I run and no oil problems with 1.2 60's with a few bumper rides.
Old 03-05-2014, 07:09 AM
RacerXLs1's Avatar
I had a stock pan on mine.
Old 03-05-2014, 04:54 PM
samdogmx's Avatar
autokraft here.
Old 03-05-2014, 06:20 PM
Twin turbo c5's Avatar
Run a stock pan.
Old 03-05-2014, 09:25 PM
a.white86's Avatar
Yea it's a LQ9 based motor. So stock pan seems to be the consensus?
Old 11-03-2014, 06:40 PM
LSXFORMULA99's Avatar
I am curios also. I am running 1.2 60ft with stock pan. only seeing 25 oil psi at the turbo inlet at full boost. Do I need a different pan?
Old 11-03-2014, 09:58 PM
6 Second Club Moderator
LASTLS1's Avatar
I use the Moroso.
Old 11-04-2014, 02:52 PM
meatheadgn's Avatar
I use the C5 batwing as the Vega sat so low in the front I needed the ground clearance. The Batwing saved me as the GM swap pan I had sat within an inch of the ground....ouch.
Old 11-04-2014, 04:21 PM
ezstriper's Avatar
running stock camaro pan
Old 11-04-2014, 07:19 PM
samdogmx's Avatar
Drew, steal Jordan's moroso he wont be needing it for awhile.
Old 11-04-2014, 08:09 PM
soundengineer's Avatar
Anything that can gain you more oil volume and some baffles is a good thing..
I prefer the moroso 20142
Quick Reply: What oil pan for turbo motor?
