Another 5.3 jy build question, what turbo/cam/stall/gear for 9's?
Old 03-05-2014, 12:18 AM
McNasty's Avatar
Default Another 5.3 jy build question, what turbo/cam/stall/gear for 9's?
Trying to help a buddy out, he's looking for 9's in a backhalved s10, should be fairly light with plenty of room for a tire.
Gonna be a street/strip toy with a few ambitions like everyone else, just trying to see where we should go with it.
So far we've got the 5.3 and a th400, looking to stay with stock 5.3 heads, ls6 intake, and whatever cam would work best. Considering E85, he isn't sold on it yet.
Been considering an s475/480, but would like to be able to comfortably be in the 9's, hopefully this isn't too lofty of a goal.
Thoughts/suggestions on turbo/cam/converter/gear to start with? Been looking around here and there but would like to get some input before we throw together a **** combo. Thanks in advance.
Old 03-05-2014, 05:52 AM
LS1NOVA's Avatar
S475 1.32AR, LilJohns Stage 2 cam, PTC converter, 3.25 gear, E85 for sure.
I assume it has a big tire and a transbrake? Install those parts, put it on kill on the transbrake, if it hooks it should go 8's.
Old 03-05-2014, 10:22 AM
McNasty's Avatar
No trans brake yet, using a leftover th400 for the time being I believe. Big tire will be on it, by chance are there any similar builds/threads you have handy I could take a peak at? thanks
Old 03-06-2014, 12:00 AM
McNasty's Avatar
Anyone else wanna throw me a bone here?
Old 03-06-2014, 12:45 AM
408RAT's Avatar
Think ls1 nova has it pretty much spot on mate. I'm also aiming for 9s, but putting together a slightly different combo. Iron 6.0 with L92s, s475 1.32ar, tick cam, ptc converter through a glide and probably 3.5 final. My biggest issue is gonna be leaf springs and a 275 tyre. Gonna run e85 as it seems to be a lot more forgiving while the tune is being sorted. Good luck
Old 03-10-2014, 11:52 AM
Sales@Tick's Avatar
Depending on weight I have a 217/225 and a 223/223 I like to use for turbo 5.3's.
I like the S475 or the S476R. With a 5.3 the 83mm turbine wheel can also be utilized depending on usage and RPM of the combo.
Shoot me an email for more information.
Old 03-10-2014, 01:39 PM
Forcefed86's Avatar
I managed 8's at what I'd assume is 400-500lbs less weight than you'll be without much motor wise. Just focus on your drivetrain and converter as said.
Cheapo S475 with a decent cam from of the vendors, e85, springs, MLS Hg's, and Studs. Should be cake!
Old 03-10-2014, 04:14 PM
McNasty's Avatar
Thanks guys, Martin I'll have him send you an email so that you guys won't have to deal with a middle man, appreciate it.
Quick Reply: Another 5.3 jy build question, what turbo/cam/stall/gear for 9's?
