torque converter help
Old 03-05-2014, 06:30 AM
millman83's Avatar
Default torque converter help
hey guys, I have a 1998 ls1 that I done a swap with and the trans that came with it took a dump, so I found one at a great price with a fresh rebuild. It came out of a 98 truck, so I know that I have to use the spacer adapter, but my problem is I have about 3/4 - 1 inch gap between the flexplate to tc. I measured my old tc that came factory with motor and from pads to end of pump shaft is 6 1/2 in, and on the other tc is 5 7/8 in. So i'm thinking that is my problem for no pump engagement. So are the tc from gen 3 to gen 2 different thickness?
Old 03-05-2014, 07:09 AM
Circle-D's Avatar
Can you take some pics of the transmission bellhousing/input shaft area and the converter. I think we have a mismatch of parts. From there we can determine what flexplate you will need.
Chris
Old 03-05-2014, 09:17 AM
millman83's Avatar
I swapped the bellhousing from the original trans to the new
Old 03-05-2014, 01:19 PM
Circle-D's Avatar
Sounds like we have a LT to LS issue. But need pics to verify, that is the easiest way to be sure.
Chris
Old 03-05-2014, 04:27 PM
spy2520's Avatar
I think the LS based stuff didn't start til 99 for trucks.
Old 03-05-2014, 07:01 PM
millman83's Avatar
I figured it out, I was told to swap the bellhousing from the ls trans to the older one, after some measuring, the LS1 bellhousing is about a inch longer, therefore spacing my tc and flexplate out that same distance, so I'll swap bellhousing back around and should be good to go. Thanks guys for all your suggestions.
Quick Reply: torque converter help
